Question about Radio Communications
Where can I get a DC power cord for a Midland 75-779 handheld CB radio please?
Posted by JohnDAVIS on
ADMIN Canada
    Top Expert:
  • Radio Commun... Master
  • 40,357 Answers
Edited question for clarity.
The Midland chargers are in this link. Different models so check the voltage before purchasing. There should be a sticker on the back of the set.
https://www.google.com/search?q=DC+power+cord+for+a+Midland+75-779
Posted on Sep 17, 2021
Midland cb radio 40 ch transceiver
Here you go
OWNER'S MANUAL midlandusa.com - Midland Radio
https://midlandusa.com > uploads > 2016/12 > 75-...
PDF Midland 75-785. 40 CH AM HANDHELD CB TRANSCEIVER. 78-785 is a 40 channel Citizen Band Mobile operation, that is big on performance.
15 pages
HANDHELD CB RADIO - Midland Radio
https://midlandusa.com > uploads > 2012/06 > 75-...
PDF Sep. 10, 2012 - Midland 75-785. 40 CH AM HANDHELD CB TRANSCEIVER. 78-785 represents state-of-the-art high-tech engineering. Designed for 40 channel Citizen ...
8 pages
Midland 75-785 Owner's Manual - ManualsLib
https://www.manualslib.com > ... > Radio
View and Download Midland 75-785 owner's manual online. ... DC 13.8V CHARGE 40 CHANNEL CB TRANSCEIVER 75-785 SQUELCH VOLUME DC 13.8V CHARGE page 4.
75822 HANDHELD CB TRANSCEIVER User Manual G-300 ...
https://fccid.io > Midland Radio Corporation > 75822
75822 HANDHELD CB TRANSCEIVER User Manual G-300 owners guide Midland Radio ... Owner's Manual Model Number 75-822 Features Include: 40 CB Channels 10 ...
USER MANUAL Midland 75-822 40-Channel 2-in-1 CB Radio
https://www.search-manual.com > midland-75-822-40-...
User manual, Midland 75-822 40-Channel 2-in-1 CB Radio, Midland, 75-822, 40-Channel, 2-in-1, CB, Radio, with, Weather, Alerts.
Customer has lost his power supply cord. where can he purchase another cord. power cord is three prongs.
  • Hi, I can help.
  • For the Radio Shack TRC-447 this is just a standard 3 PIN DC cord. Many CB's use the same cord and they are interchangeable. Some Cobra, Uniden, Radio Shack use the same cord. Texxcomm is a great place to get parts from.
  • If you have any coimmments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Cobra 75 wx st fuse keeps blowing. As soon as I plug the transceiver into the connector box the fuse blows.
Hi and welcome to FixYa,
Initially, check the reverse protection diode, D18 (1N4004). It would be located / connected at the power board of the DC connector.
Good luck and thank you for asking FixYa.
My Cobra Road Trip handheld CB won't switch over to battery power when I unplug the 12v adapter. How do I open the casing to check if the spring behind the connector can be repaired or replaced?
Make sure you have good batteries in it ,and installed correct. There should be a switch behind the battery,i think.... but there is a switch on it for ac or dc,switch it to dc,make sure you have the ac plug adapter end unpluged from it in order for it to work......hope this helps.....
3helpful
Cobra HH 40 charger specs
I have a Cobra HH-40 CB radio and am charging it as I type. The included charger is rated at 16V DC, 100mA. The pattery pack charges 10 AA rechargable batteries (the manual specifies NiCd, but you can also safely use NiHM). The 12V DC car charger included cannot be used to charge the battery pack, but can power the radio.
1helpful
The voltage for charging and plug-in power, cobra hh35?
the voltage for the charging is 12 volts dc the charger is a 110 volt dc 12 volt to the radio if you lost your charger you can get a aftermarket at any radio shack store just be sure you take the walkie with you when you go so they can match up the rdio plug end.
Cobra 38 WXST Handheld - Which is positive on DC connector?
To my knowledge, it is positive. To confirm, pls look closely at the markings beneath the DC power jack.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Ekse
Are you a Radio Communication Expert? Answer questions, earn points and help others
