05,starex 2.5 crdi leaking at oil galley plug. How do you remove this plug. I've tried with Allen wrench but it won't budge.
Thank you Mr Ken Green. I'm new to this forum and I don't know how to reply to answers.
Posted by Paul Johnson on
  • 2 more comments
  • Anonymous Sep 17, 2021
    stop posting car question to COMPUTER REPAIR HELP are you lost?
    post here.
    IN CARS/ (the browse button is above to use and takes 2 clicks)
    CAR Hyundai 2005, 2.5Liter CRDI (diesel) ( why leave off Hyundai?)
    plugs like the stick for reasons:
    1:cross threaded by noobs. (never good nor easy fix) avoid noobs touching car. hand fit parts first is cure .
    2: rusted in (aka. corrosion)
    3: last person used, extra hard, LOCTITE, use heat to remove those per the label on the TUBU of locker
    4: a weak wrist
    5 not turning CCW (righty tighty lefty loosey)?
    try heat, on surrounding area. or even with fully hot engine, (use gloves to not get burned) PPE
    mech. 101 rules. all.
    WHY NOT POST TO CARS and not computers. HERE it is , 2 clicks on browse above.
    https://www.fixya.com/cars/hyundai/troub...
    to replay , click comments, DO NOT start 5 more posts. 1 computer, 1 problem , do not./
    post to cars not PC
    post to Hyundai
    post why you can not have real mechanic fix that and NOT make it worse as mose NOOBs do.
    if you crack the block, you will not be happy
    most plugs are put in hard, and with sealant or Threadlocker.
    if some noob put in NPT plugs (USA) into those metric threads Hyundai uses, it is doomed,
    use heat,
    turn it CCW
    this is basics here and if i must tell you that , then you lack that. and is not a good sign at all that.
    first do no harm.
    respond by clicking your post (comments button)
    do not force it out , lacking heat or it will be damaged , CCW is out. not CW
    assume it has theadlocker if you fail to assume that you may well wreck it. (strip out)
    see this page, what if used 300f or 450f , loctite?
    we use heat, and raise heat until the locker softens and allows CCW movement. (this is a skill set so pay the man to do it)
    no plug diameter told by you or i would have told you , max CCW torque is safe on any screw or plug made.
    we look it up. for example 10mm would be about 10ft/lbs max. CCW. see? or you strip it out.
    and in aluminum block worse. Soft that, unlike hard cast iron blocks, (no photos posted you)
    http://wdarc.org/Loctite%20Guide.pdf
  • EthelEdwards
    EthelEdwards Sep 17, 2021
    Everybody can earn $750 Daily... Yes! you can earn more than you think by working online from home. l have been doing this job for Iike a few weeks and my Iast week payment was exactIy 3871 doIIars.
    See More Info....https://CashApp1.Com
ADMIN Canada
    Top Expert:
  • Computers & ... Master
  • 40,381 Answers
Paul, I replied to this yesterday. Read this and please don't make posts like this again. It just does not work, you are wasting your time and not helping yourself! Click on this link and read my reply.
https://www.fixya.com/cars/t29839554-thank_mr_ken_green_allen_wrench_plug
Posted on Sep 17, 2021
  • EthelEdwards
Thank you Mr Ken Green. Is it a Allen wrench plug
Doing feedback to an Expert as a new post doesn't work because this post has no context whatsoever to the your original post. You need to put this comment here to Ken Green directly by clicking COMMENT under his comment to you. The main benefit is that Ken will get a notification and give you further assistance.
https://www.fixya.com/cars/t29839539-05_starex_2_5_crdi_engine_small_hole
tip
Changing Powerstroke injectors
A key step most DIY'ers forget when changing the injectors is to remove the UVC (under valve cover) oil drain plugs. These plugs drain the excess oil from the oil passage so it doesn't leak into the cylinder and cause hydro lock (clyinders full of fluid) and damage pistons/rods. To do this you remove the valve covers and then the gasket as well as the injector harnesses. The 2 drain plugs are located directly underneath the 2 wiring harnesses (front and rear). This requires an allen wrench (4.5mm I believe) and do not torq when tightning). You must remove both to allow maximum oil drainage.
05 starex 2.5 crdi engine. There is a small hole on the passenger side back of the cylinder head.its leaking oil. What is this hole it looks like it has a Allen head plug in it
Hello. That is an 'oil galley' plug; engine oil flows through there whenever the engine is running. Somehow, that 'plug' loosened; I don't know how or why. Good luck and keep me informed; if you want to.
Removing the drain plug and oil filter on a 2005 pontiac vibe
They sell octagon shaped oil filter wrench that conforms to your oil filter's shape. Take your replacement oil filter, then call the auto parts store in your area and ask if they carry oil filter wrench for your car, If a standard filter wrench keeps slipping off, wrap 2 or 3 layers of rag to the old oil filer, then attach the oil filter wrench. The drain plug turns left to loosen, right to tighten. If you're using a socket wrench, attach a 1/2-inch pipe to the handle to increase leverage (cheater pipe). Another solution is a strap oil filter wrench
4ec92b1e-c8dd-4d72-80fb-d33e80108759.jpg ffea9219-514a-4c9b-9a3c-0e0d08ec1f7b.jpg 78fa3f58-edb2-447b-9cd0-64dadb0810b9.jpg
Fan pulley nut won't budge
it may be reverse threaded
How to remove the headlight of hyundai starex 2000
can you give me instruction on how to remove the headlight assemble of Starex CRDI 2006 model
2answers
I have a single -handle Moen Torrance 87480 kitchen faucet that needs the cartridge replaced. (I had Moen ship it to me.) My problem is, I can't remove the single handle using my 3/32 allen wrench. When...
Should be coming out if head not stripped or threads inside at set screw aren't stripped. Can you tell at all with perhaps flashlight if set screw is turning at all? Look like it backing out?
1helpful
What is the size of the allen wrench needed to fit the oil pan drain plug in a 1995 toyota celica
The oil pan drain plug should require a 14mm hex head wrench to remove. The transmission pan requires a 10mm allen head socket, or wrench to remove. Are you sure you're trying to remove the correct drain? The oil drain should be on the passenger side and on the rear corner of the pan.
1helpful
I have an oil leak coming from a plug not a spark plug on the passenger side near the oil filer.
Look at the plug to see if it has a square hole in it,or allen,if so,it is just a oil galley,remove it,and clean the oil off the plug,and the hole,then use teflon tape,or liquid around the plug,and reinstal the plug.
Computers & Internet Logo
Ekse
