Doing feedback to an Expert as a new post doesn't work because this post has no context whatsoever to the your original post. You need to put this comment here to Ken Green directly by clicking COMMENT under his comment to you. The main benefit is that Ken will get a notification and give you further assistance.
https://www.fixya.com/cars/t29839539-05_starex_2_5_crdi_engine_small_hole
Locate the fill plug in the center of the transfer case facing the rear. The fill plug is a hex head bolt.
Remove the fill plug and check the fluid level. Insert the short end of an L-shaped Allen wrench into the hole. Spin the Allen wrench slightly and remove it. Some fluid should be present on the tip if the unit is full.
Attach a screw-on hand pump to a bottle of Mopar ATF+4 type 9602 automatic transmission fluid. Insert the other end of the tubing for the hand pump into the fill plug hole on the transfer case.
Pump fluid into the transfer case until the fluid is flush with the bottom of the hole. A small bead of fluid will drip out of the hole when the case is full.
Reinstall the fill plug and torque it to between 15 and 25 foot-pounds of torque. Hand-tightening the plug and turning it 1/2-half turn further with a socket wrench is equivalent to 20 foot-pounds of torque if you do not have a torque wrench available.
