Question about LG Washing Machines
Why does the drum hangers on my LG FUZY LOGIC 13 KG Keep on hooking out then the drum hang skew
My LG FUZY LOGIC 13 KG THE HANGER RODS KEEP ON UNHOOKING , WHAT MUST I DO TO STOP IT
ray gallant
    Top Expert:
  • LG Master
  • 73,385 Answers
Call a repair service locally
Posted on Sep 15, 2021
My LG Fuzzy Logic Turbo Drum 13 Kg Top Loader don't stop taking water at any level and then it overflows. What can be the problem or how can I sort this issue out
there is a pressure valve inside.........look around the drum with lid off.......look for thin pipe from bottom of drum to small unit.........that is the valve switch.........remove pipe blow and suck on the valve switch listern for a click.........no click.......replace the valve switch........
cheers
1helpful
How do I hang a picture using picture hooks?
You should have two 'pin' nails that hammer through the two nail guides at top. You picture will need wire hanger which settles into the lower hook part of the picture hook.
2answers
The bras 365+ how come it will not stay flush with the ceiling. Help!!
What I have read is that you must pull the wire through to gather the cone up to be flush with the ceiling.
Seriously I would return it and get another lamp. This does not seem like a good system to me from what I have tried to find out for you.
Apr 03, 2013 • Home
Uninden uho65sx keylock off
you have 2 options or a) call locksmith b) follow the steps mentioned.
Instructions
    • 1 Unwind the metal coat hanger so it's straight. Bend the end of the hanger so the tip resembles a hook.
    • 2 Slide the hooked end of the hanger between the window and the door frame right in front of the side of the door handle that is closest to the side mirror. Push the hanger down 1 1/2 feet and make sure the hook is facing you.
    • 3 Pull up and down on the coat hanger until the hook grabs the metal lock arm. The door lock handle will start to move once the hook has grabbed it. Pull up on the coat hanger until the door lock releases, then open the door.
    GOD BLESS YOU
My keys are locked inside how should I open
Instructions
Straighten out the metal coat hanger and bend one end of the hanger into a hook shape. Make the hook about one inch.
Place the end of the metal coat hanger with the hook on it between the window and the frame. Place the hanger 1/2 an inch behind the door handle toward the the edge of the door closest to the rear door.
Push the hanger down about two feet into the door frame. Pull up on the hanger until you feel the hook catch onto the metal arm inside the door frame that controls the lock. You may have to try a few times before the hook catches the metal arm.
Pull up on the hanger once the hook has connected to the metal arm until the door lock unlocks. The lock handle on the inside of the car will move once you have connected the hook to the metal arm that controls the door lock.
1helpful
I have a nv30 infinity vacuum. The handle is clogged with a sock right where the flexible hose begins. I cannot reach the sock even after removing the telescoping tube. How can I unclog the handle?
Hi Jackie ma268...
You need a metal coat hanger nd a pair of pliers.
You will straighten out the coat hanger with a pair of pliers, except the end that you hang the clothes hanger up with, because it has got the hook already made..
After you have gotten the hanger straight, you will take the hook of the hanger and make a smaller hook that will slide easy into your hose with the hook being able to catch the sock ...once it has caught the sock, then twist it a few times so that it will get caught up in the sock really well...then pull the sock out of the hose...Job done.
Please take time to rate me
Sep 06, 2011 • Vacuums
How can use to LG LCD tv in wall hang
First you get the wall hanger. Screw one part to the wall. And then screw the other part to the TV. then you hang the TV on the part screwed to the wall.
Hope this solution has been helpful?
Tailpipe is hanging very low
Hi. Under or near the tailpipe, there are rubber and sometimes steel hangers that are placed onto the sides of the pipe structure. These move with the assembly to provide little flexibility during travel. These hangers also are there to keep the pipe/muffler assembly from dragging or hanging to low. When the hanger assembly becomes unstable or damaged, it will allow the tail pipe assembly to hang low or sometimes drag the ground when you hit a bump. The necessary actions are to raise the vehicle high so that you can inspect the exhaust tail pipe assembly for broken hangers or steel bracing devices. replace any rubber hangers that may be snapped or missing form their respective locations. If you are uncomfortable with raising the vehicle, i would take the unit to a local muffler/exhaust shop for the inspection.
5helpful
3answers
Locked out of 96 chevy cavalier
You can use a wire hanger with a hook bent onto the end fairly easily if you slide it down the window and try to feel around to hook onto the lock mechanism. It may take a bit of patience, but I got into my 2000 with not too much trouble. Then do what I did immediately afterwards - get another key cut to keep in your wallet...
Washing Machines Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
