Question about LG Televison & Video
I have a LG Flatron MC236D. My screen has gone white with the numbers V3.02.0 on the top of my screen. I've lost my tv remote ages ago and non of the other tv remotes work for it ??
Norvan Martin
Well, you could try a universal remote. Then just I press the Exit and OK buttons together and then click on input/source and bring up the HDMI input.
If that doesn't work, then you're not getting a signal from the mainboard.
Check the cable connecting the mainboard to the T-Con Board, (LVDS Cable) try reseating and cleaning ( Isopropyl Alcohol) Clean LVDS Cable, at both ends.
Posted on Sep 15, 2021
Hello guys, I have a LG flatron Tv LG m2362dp and an ASDA remote Urc220-D4f, & need help setting up the remote for this device, could please help and advise on how to do this.. many Thanks..
The remote instructions show codes to use to set-up the remote. There is an extensive number of these codes and usually indexed according to TV's identity. It is easily done with that list provided by the remote manufacturer. Check their website, perhaps there is a PDF of the user guide with the codes.
1helpful
It is displayed "power only V4.15" and the screen is lank white
Try pressing the EXIT button on the remote control, it is possible the TV has gone into the Aging Mode, if so the Exit should clear it.
Lg flatron plasma
LG MT 42PZ40B Owner Manual
Page 18 I believe.
Good luck
Semper Fi,
Z
2answers
Hello i have a 19 inch LG M197 WDP monitor/tv, when i switch it on the screen is white with a little gray bock that flashes and slowly moves across the top of the screen reading v3.02.0 which i presume is...
I also had an LG M197WDP tv/Monitor with the same problem. It comes straight on when plugged in, but with the blank screen and scrolling version number across the top.
The solution:
1. Use the remote control (check batteries first)
2. Point at the working TV and press either MENU or EXIT
3. Static should be seen on the screen.
4. Switch to standby using the remote, by preesing POWER button.
5. Switch back on using the POWER button.
All should then be working normally
46helpful
2answers
When switching television[flatron m2262d]on shows white screen only with v3,09.0 at top of sreen
I had the same problem with my new LG. To fix this, press exit on the remote control then power off on the remote. Turn the TV back on and all should be well.
Hi, I have an LG Flatron TV which I bought 6 years ago. Good picture, no problems until now. I put the set on standby via the remote. Later, when I put it on via the remote all I got was sound and no...
Since the screen keeps turning off and sound only remains have a look at the inverter board for any buldging capacitors which look like blue cans, there is most probably a short in the inverter and the powersupply is sensing this thus turning it back into standby to prevent damage to the tv.
jonno
30helpful
My LG flatron golden eye tv got Child Locked -
dear sir,
my tv had gone child lock problem & one chenal show the tv. please slove this problem. because remote has been not working.
Televison & Video Logo
Ekse
