Question about Philips Televison & Video
I have a 55in Philips flat screen the light blinks 6 times and the screen lights up but no picture
Posted by Jonathan Weaks on
    Top Expert:
  • Philips Master
  • 76,749 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://elektrotricks.blogspot.com/
Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Search the sites by type in the brand name of your set, in its search box at the right column. View it on a desktop or in web View by mobile. Mobile view has no search box.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Posted on Sep 14, 2021
55in. was on and screen just went black along with sound
I had this problem with VT470M and the white light would come on but the screen would freeze on opening screen and then after a couple times the white vizio light would come on but no picture no sound. I ordered a new main board after troubleshooting all the voltages and it worked. Vizparts.com trade in for 150.00. Well worth it. Have you fixed this problem yet?
Phillip 42 flat screen plasma blinking red light 6 times
most likely the power supply, buy it from http://www.shopjimmy.com/ they have the best prices anywhere. and techs to help if needed
Power light blinks 4 times pauses then blinks 6
Not sure what the code means (mine occurred after a slight power surge...maybe an overheat or some kind of overload), but after leaving the tv off for 10-15 minutes the flashing stopped and the picture was fine on restart. I know you've probably figured this out already, but hope it helps somebody because Philips apparently does not want to make it easy to figure out what these codes mean.
2answers
Turn tv on power light comes on but has no sound or picture then the standby light comes on and flashs and power light goes off
if the standby light blinks 6 times it has a bad backlite board (the most common with that set) other than that i will need to know how many times in a row it blinks. thanks....techman
My Philips LCD model 52pfl7422d/37's red light blinks 6 times slow and then 3 times fast. Any idea what disaster this coded message refers to?
if no sound and no picture -- check the fuses and disconnect all cables -- wait one day and re connect - if you solution -- might need a new power supply board
Philips tv blinking red light
I've seen this problem before with Philips. 6X3X blink was the X-sus or Y-sus boards. In other words, the TV cannot make the picture on the screen properly, so it won't even try and will shut down.
I've also had difficulty getting these parts from Philips (even while being an authorized service center). If you have an authorized service center near you, you might want to give them a try because I don't believe they were too expensive, just hard to get.
I hope this helps you...
5answers
Philips 37 flat screen
U better have it checked by a qaulified tech
Televison & Video Logo
Top Philips Televison & Video Experts
 Francisco Mauricio...
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
