KDL-46V3000 HDMI Filters. I used the filters from one of the HDMI ports to fix HDMI1 and now need to get more filters to Fix HDMI2 , Does anyone know what value these are.
These are the Filters between the HDMI port and the HDMI chip. I am having a hard time sourcing the part. I see that it is FL4304 1-813-880-11 INDUCTOR 0uh
Posted by Rick P on
Fred
    Top Expert:
  • Televison & ... Master
  • 34,958 Answers
Component number?
You need to be specific as there are many 'filters'.
https://elektrotanya.com/sony_kdl46v3000-sm.pdf/download.html
Posted on Sep 14, 2021
  • Rick P Sep 14, 2021
    I found the Part # , it is FL4304. I am having a hard time sourcing the part.
  • Fred
    Fred Sep 14, 2021
    Order a Sony part from Sony.
Switching from HDMI2 watching computer back to HDMI1 to TV channels I have no picture coming on the TV. Why ?
Look if there is a FIRMWARE update for your model of TV and the SAORVIEW.
Many a times, the TV lock in with the frequency and will not release until the proper reset command arrives.
Try switching to a different resolution on the computer before you switch HDMI port
Is HDMI4 correct or HDMI1?
depends on what you plug into on back of tv
is it a dvd player with a hdmi cable ?
or is it a tv antenna cable ?
or is it AV cable ?
The input select on the tv menu must be the same as the port you plugged the cable into
DTV = Digital Tv
AV1 = Av input 1 the yellow plug type cable red and white audio plugs
HDMI1 = HDMI1 port
HDMI2 = HDMI2 port
HDMI3 = HDMI3 port
HDMI4 = HDMI4 port
component in looks very similar to av in so if using av cables
use av1 in port rather than component in .
Sony KDL-40NX711 HDMI PORTS STOPPED WORKING. EVERYTHING ELSE WORKS FINE. WHAT WOULD CAUSE THIS TO HAPPEN?
Sounds like everything works. Your remote has an input menu. Have you cycled it around to the right component? i.e. HDMI1 or HDMI2, or DVD, even PC?
If not, try that.
1helpful
The light just blink green it doesn't let me do anything but blink green.
If you plug the Roku into the back of the TV in an HDMI port, you need to hit the Input button on the TV to change (probably) from HDMI1 to HDMI2. Once you are on HDMI2, you should see the Roku emblem. Then you need to set up the Roku to see your wireless signal.
Switching HDMI inputs
Plug all cables in the ports in the back of your television, the use the remote of the television select Source scroll up or down for required hdmi channel select buy stopping it on the channel then press ok
1helpful
I have a sony kdl-46v3000 tv, try to hook up my PC using dvi (computer) to hdmi (tv) cable, the tv still has no image. Please help. Thanks
I would contact Sony customer service on the phone with the model number to see if this is a known issue or they have an answer--takes time but may be the best way.
Turn hdmi2 on
hdmi is auto detecting and shouldn't need to be turned on. try plugging your hdmi1 device into the hdmi2 slot. if switching devices around doesn't get hdmi2 working, that jack is likely broken. all the hdmi ports go into the 1 main board inside, and a lot of times you would have to replace that board to fix. if only 1 jack now works, you could also get an hdmi switcher, and then plug all your devices into that, and then just plug the switcher into the working jack. let me know if I you require further assistance.
Cable is connected to HDMI1. When Tv is turned on, the screen is corrupted/distorted. Color is messed up, wavy vertical lines, from middle of the screen down. But there is sound. What is wrong/ how can we...
Try first by using another port. Select HDMI2 and select proper "Input" from remote. If you get the same results, cheap HDMI cable. Replace it. If it is only on HDMI1, then there is a problem with the contacts. Warranty or just use HDMI2, 3 or 4 etc. Worse case senerio, you can use the 5 cable component cables as they can also carry HD signals.
No signal on HDMI1. Had to switch to HDMI2
Ur HDMI/1 might be shorted,will not work again.But u can tries unplug,replug the tv an hour later,let it reset it self back to factory setting.Who know might get lucky,it work again.
No picture on hdmi2
First of all connect the Direct TV box to HDMI 2 and see if it works there. If it does then the next step is to connect the DVD player to HDMI and see if it wors there. If not then connect the DVD player to the TV using the component inputs and if the DVD player works on those. If it does then maybe the HDMI interface in the DVD player no longer works as it needs to communicate with the TV.
Televison & Video Logo
Top Televison & Video Experts
Ekse
