Question about Viper Computers & Internet
I have the Dodge Viper and we are unable to charge it for some reason.
The serial number is 1101-12 -013149
Posted by Tom Johnson on
Arnie Burke
  • Viper Master
  • 6,857 Answers
Battery is probly worn out or a connection issue
Posted on Sep 14, 2021
1helpful
How do I get to the battery in a 1997 Viper Rt/10
You can use a battery charger or jumper cables on the battery access post and any good ground point.
1995 dodge viper OBD codes
I believe 1995 Viper has OBD I codes only.
2005 dodge dakota horn honks while arming vehicle with Viper alarm instralled
You need to look under the dash for the model number then contact viper support
Serial number
We are unable to supply serial numbers due to legal reasons, sorry
1helpful
2answers
Cant find the battery
Check the front of the wheel well. On a Plymouth Breeze/Dodge Stratus it's the driver side Wheel well but might be different for a Viper
Need to know pcm wire connector location numbers
The numbers are on the PCM not the plug.
1994 Dodge Viper will not start after storage and battery drain.
With the battery charger connected or a jumper battery simply click the alarm key fob on and then off. This will reset the alarm and the car should start...had mine towed to find this out
Alarm goes off for no reason 20-30 minutes after i lock doors
remove the battery from your remote and see if works
Viper LS6
cable serial de pc a viper panduit LS6 o como lo puedo hacer la conexion
Computers & Internet Logo
Top Viper Computers & Internet Experts
Ekse
Are you a Viper Computer and Internet Expert? Answer questions, earn points and help others
