Question about Samsung Televison & Video
How to fix single green vertical line on Samsung TV
Hello, I have a single vertical green line on the right side of my TV. I'm afraid it may be a panel issue, but thought I'd ask. Model Code: UN75MU6300 Serial No. : 06LL3CBJA08271Y Software Version: T-KTMAKUC-1290.3 , BT - S
Posted by Bob Longoria on
Arnie Burke
  • 6,821 Answers
Easier to buy new set then repair. It will b anothr item next...Tv wears out like a computer or fone
Posted on Sep 14, 2021
I have a Samsung 60 Inch plasma television. The problem is that there are green vertical lines on one side of the screen.
It appears to be a known issue with Samsung Plasma.
How do I get rid of the green line on my Samsung TV? Unplug all cables except the power cable, turn it on and see if you still have the green line. If without any image input, the line is there, you have a faulty LEDTV. If it goes away, it's the cable/connector. How do I fix the green vertical line on my TV? Slightly dampen a soft cloth and apply gentle pressure to the stuck pixel line. Don't press too hard or you may make the problem worse. The idea is to gently flex the screen material and encourage the pixels inside to shift out of the permanent "on" position. Work slowly, applying gentle pressure along the whole line. https://www.google.com/search?q=Samsung+60+Inch+plasma+television.+The+problem+is+that+there+are+green+vertical+lines+on+one+side+of+the+screen
How to fix vertical black bar on tv
You are not able for resolve this error your self, you should send it in for repair.
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
1helpful
3answers
Vertical green line on left side of my laptop lcd
lenovo G450 a vertical line appears on the right side of screen. it is of pink colour.
Green vertical lines,minor. flashing goodback ground pic good sound . i have samsung dlp tv model hl-r4667w
the lines are from the vertical control, theres a minor short on the vertical board if not fixed the power supply will short and whole tv will go green call repair shop and get short fixed
Thin green vertical line on the lft side of LCD TV
redone all connector inside of the tv
like those flat wire you have to check allthose flat and clean and redonne try that
1helpful
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Televison & Video Logo
Ekse
Demonic-2011
Demonic-2011
