Question about Toshiba Office Equipment & Supplies
Smudge down one side-- Toshiba
I am getting consistent black ink smudges down the back edge of each paper. It looks like something from a drum that's abut 3/4 inch wide. I've cleaned everything I can access to clean. I wish I could submit a photo.
Posted by Angela Hansen on
  • The Spaminator
    The Spaminator Sep 14, 2021
    Hi Angela Hansen, Is the black smudge set or comes off ? Wondering if fuser area has a problem maybe with the fuser roller. Can you please add details in the comment box?
Don A
  • Toshiba Master
  • 2,911 Answers
Https://www.tonergiant.co.uk/blog/2017/05/black-lines-down-the-page-4-causes-and-how-to-fix/
Sadly, the poential fix is a step by step process where each step either solves the problem or doesn't thus forcing you to move to the next step. The procedure on the above listed page includes cleaning, which you indicate having performed. Each time you try to print, you undo your cleaning in this instance. Look for advice for your specific model of printer. Toshiba has interactive tutorials. https://tbs.toshiba.com/tbs/support/#downloads
https://www.atechnj.com/what-to-do-when-your-printer-leaves-black-lines-or-smudges-on-paper/
Posted on Sep 14, 2021
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Ink smudge on right side of paper
Chances are high that the process of clearing the jam has resulted in ink being released from the cleaning/resting pad area based over on the right hand side (where the printhead sits when not in use).
This waste ink has probable come into contact with the rollers and other parts over on the right edge of the paper.
You'll probably see this ink slowly fade out and disappear over time. If it doesn't however there's something effectively feeding things so check the resting pad for a loose tube, overflow, puddles, etc...
If there's anything like that, report back (preferably with images).
I am having issues with smudges on the Xerox 7335. I honestly don't know where to begin, but I have opened the paper drawer to see if ink may have fell down there, but there is nothing. Any advice?
open the left side door and unscrew the two green screws that hold the fuser in the machine. look at the two rollers in the fuser. one is black and the other red i think. see if any toner is stuck to either of them, if so you will need to replace the fuser. check to see if the smudge is only with back or one of the colours. If it is on everything printed then the fuser is probably the cuplrit. If not then check each of the drums for tears on the blue surface. the drums are the same so can be swopped around. If back is smudged but colours are ok then the back drum is at fault.
1helpful
Printing has smudge on edge
If it is right along the edge then the drum (well the cleaning blade of the drum) is faulty. In a unit like that I suspect it is all part of a toner cartridge. Try replacing that and I think you will be good.
4 - black ink smudges (1/32" wide x 1/16" high) in right margin
Very nice trouble shooting. The image defect you describe point to the OPC or drum unit this is essentially the toner cart. In your case black. Measureing the distance between repetitive defects is a sure way of diagnosing problems such as yours. Again nice work.
Google repetitive defect ruler for your model to help in the future.
Hope this helps
Black Smudge of ink along top edge paper Brother Intelifax 2800
try cleaning the grid on the drum unit otherwise there could be some thing on the fuser preasure roller.
2answers
Black smudge on side of paper when printing quanities
Hey, Pleas check Black imagine unit,if needed change it.
Ink smudges
Pease check:
thet consumables is originals,
drum cartridge is not damaged
transfer belt is clean and not damaged.
you may have problem there, but if not you can try update firmware, maybe its a firmware problem.
first check consumables and if possible try changing them
Ink smudge on corner of brochure paper
Ink getting onto the paper when it should not is usually a sign the waste ink tank need cleaning out. Go to www, fixyourownprinter,com for a deeper insight. Also the Canons own Tech Support team
Open Questions:
Top Toshiba Office Equipment & Supplies Experts
Ekse
Alvin Barnabas
Alvin Barnabas
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
