Question about Roku Televison & Video
Hi, my 75" tcl roku does not have a picture, however if i flash a light in it , i do see a content behind the black screen, which board do you recommend replacing?
Posted by simon b on
Larry
  • Roku Master
  • 3,133 Answers
You can replace every board in the TV and chances are it won't fix it. Like 95% of sets that don't have backlights it's a backlight strip issue, the backlight strips have failed and the power board is shutting down the negative return path because of over current. On a set this sie it won't be easy to do yourself but it can be done, you will want to use suction cups to remove and replace the panel, it's very fragile and the larger the TV the harder it is to handle, order 4 suction cups on ebay or amazon. Also view some youtube vids on how to do it.
Posted on Sep 13, 2021
2answers
I have a TCL Roku TV model 65S403 and the screen recently went black. No backlight at all. We can hear it and if shut off all the lights we can faintly see what's on the tv I wanted to know if there was a...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts or search the site by type in the brand name of your set, at its search box at the right column.. It will be best to replace the inverter board as card basis.
https://elektrotricks.blogspot.com/
Changing the fuse on my TCL ROKU tv model 55R613
The mains fuse is the little black T05 sized component called a Wickman Fuse next to where the mains power enters on the power board.
Always choose an identical fuse!
My TCL Roku TV has a steady light (standby mode) when plugged in but does not respond to the remote nor can I use the app. No sound or picture. What can be the issue?
Open the battery compartment and remove the batteries from the remote. Unplug the power from your Roku device and wait approximately 5 seconds, then reconnect the power cable. Once the Roku logo appears on the home screen, reinsert the batteries in the remote
TCL ROKU HAS BLUE SCREEN I REPLACED ALL 3 BOARDS AT THE SAME TIME STILL DOES THE SAME THING
Try a different HDMI cable or HDMI input on the TV. Roku had an Update to on 12-5-2019 which has fixed this issue for many folks.
I have a TCL 55us57, when brightness is up half the screen flashes black, and it has dark spots on it ,I needed to know if that would be the led driver board or the backlights themselves
Sounds like moisture or smoke damage or maybe was electronicaly damaged un plugging plugging in while unit was still powered on and or plugged into other devices
Televison & Video Logo
Top Roku Televison & Video Experts
ray gallant
Abdul Rasheed
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
