Question about Samsung Televison & Video
Lightning struck Samsung LED tv Model UN65RU7100FXZA, Changed the Power source Board and Still not working
Not sure if just changing the board would fix it, and It didin't. There's no many more components there, speakers, and the main board. Connecting it to the wall didn't even light up the red light in the bottom and nothing happened. Any clue on what else I can try? Thank you!
Posted by Daniela MB on
Larry
  • Samsung Master
  • 3,133 Answers
Test the power board for voltage at the 13v rail, if you see the correct voltage there your main in defective, if you don't see 13 volts there then you received a defective replacement power board. This model TV doesn't have the typical 3.3 or 5 volt standby voltage, it's processed via the main.
Posted on Sep 13, 2021
Paul Carew
  • 3,625 Answers
If you did not have power surge cut off in the power line to the TV is most likely done the TV .
I have a Samsung plasma tv that got struck by lightning and wont work. I replaced the power supply panel and it still wont come on. Do you know what else it could be.Could it be the actual power cord?
Chances of lightning damaging the power cord are slim to none, unfortunately it could be almost any board in the set, check the various power supply voltages on the boards and see if they are correct, almost every board has a power supply in it
2helpful
2answers
Trying to repair a samsung led tv. It was struck by lightening. There are 4 boards in the tv. Do you think if I replace all 4 boards it would work? Could the lightening have damaged the led screen?
any answer here will be pure guessing. and the cost versus the risk of not working by replacing all four boards may make it worth buying a new tv instead.
if you were to try and fix it i would not do anything more than trying to fix or replace the power supply board. . if the power surge has gone further in the electronics. its rarely worth trying to fix
Lightning struck causing tv to not power on. No light, no nothing. Any way to find out if it's the power supply or main board? Fairly easy to repair?
I worked in a tv shop for many years...can be as simple as a fuse to literally handfuls of componenets or a fried board ( the actual board can swell up or burn) Homeowners renters insurance may cover it.
3answers
I have a Samsung tv model un50eh5300f that was hit by lightning. I have swapped the power board and the main video board. It now has the standby light but no picture. What else could be the problem
the fact that unit is nor working after a lightning strike means that all that you have done is to no avail and it will co9st more to continue with repairs than to replace the unit
use a quality power surge protector next time
I have a Samsung Plasma tv (PN59D8000FFXZA) that after my neighbors house was struck by lightning it won't turn on. What steps should I take for diagnosing the root issue?
When it get hit with any surge usually the main Board is gone, to replace it and hope nothing else is wrong, you can get a 4k LED for probably same price
Amazon com 4k smart tv 50 inch Electronics
What needs to be changed
The lightning damage is through the cable box section, i would try a new main board first.
1helpful
Why won't my Samsung UN40D5005BF come on?
Lightning damage can do a # on LCD TV's. I've seen cases where it took out power supplies and main boards at the same time. I'm not one who likes to use the "shot gun" approach. You would need to get the set professionally diagnosed in my opinion. Where did you get the main board from?? Are you sure it is a working board?
Tv struck by lightning and will not turn on. Can it be repaired or is it a lost cause?
Yes,it repairable.The tv have power at all like the LED power light indication flashes?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.No power LED light indication all.The power supply board is dead and also the Tuner signal board is dead.Must replaced both boards.
1helpful
Tv was struck by lightning, will not come on. will power supply board fix this
Well,now the tv have power to it at all?Or the tv power light indication LED light,just flashes?Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.Might solved ur problem,by replacing the power supply board,might not but the power supply board,must be replaced first see,what happen to the tv.
I have a sharp 20" (Model LC-20SH1U) That wont power on
PROBABLE POWER SUPPLY OR CONTROL BOARD PROBLEM. TAKE TO AUTHORIZED SHARP SERVICER TO IDENTIFY WHICH BOARD. SOME POWER SUPPLY BOARDS CAN BE TROUBLE SHOT TO COMPONENT LEVEL.
Televison & Video Logo
Ekse
Demonic-2011
Demonic-2011
