Question about Grundig Televison & Video
GRUNDIG 50 vle 932 bh won't boot
Hello everyone... the TV in question when I turn him on power LED blinks 2x and then it shows GRUNDIG logo on screen and afterwards he turns the backlight for a half a sec on then the power LED blinks 4 more times and 5th x it stays on... I cannot find any error codes on blinks for grundig so if you have any suggestions I would appreciate it... thx in advance
Posted by Ivan Raic on
    Top Expert:
  • Grundig Master
  • 76,749 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://elektrotricks.blogspot.com/
Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Search the sites by type in the brand name of your set, in its search box at the right column. View it on a desktop or in web View by mobile. Mobile view has no search box.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location...
Posted on Sep 14, 2021
  • Ivan Raic
    Ivan Raic Sep 15, 2021
    ty for your answer... I'm aware of the blinking codes but usually they are not hard to find aswell their meanings, but I have trouble finding them and that was the main reason why I have posted here in hope that someone knows them and pass them to me...
    ty anyway for taking time
My grundig 40 vle 6142 c tv dims after power on
Problem on switch digital, maybe on diode or integrated circuit
I have Grundig 32 VLE 6520 BH and When I find programs automaticly it finds it and it is all ok until I turn off the tv. When I turn on again the programs are gone and i have to do it all over again.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Blinking screen
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Laptop apple power book g4 boot up problem
What happens when you try to boot up the PBG4? Does it show the Apple logo on the screen? Are there any sounds or blinking LED status lights?
Grundig tv factory reset
TV Grunding 49 VLE 6523 BL reset PIN
Vizio m470nv will not come on, logo blinks orange to white.
It may not be the caps at all, a lot of the new LED Back-Lit TV have faulty LEDs. They short and pull down the power supply, and to a novice it will seem like a bad power supply. That means that you must replace the bad LED's in that particular LED strip before you can fix the problem. Not an easy repair for a rookie.
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
Televison & Video Logo
Top Grundig Televison & Video Experts
Raj Patel
Jean Thiebaux
Are you a Grundig Televison and Video Expert? Answer questions, earn points and help others
