Question about Samsung Televison & Video
Vertical Lines on Samsung TV
Hi, I have a Samsung 55inch TV UN55C6400RF. It has started showing colored vertical lines. I have opened the TV and the power board had one pin out1- which is discolored Model # bn44-00358b. Can this be bad or is it the T-Con board Model # D03464E0J09B6012066. Any recommendations on diagnosing the issue? Thanks, Sanjay
Posted by garg_sanjay on
Larry
  • Samsung Master
  • 3,133 Answers
Test the voltage at the main to make sure you have the proper voltages from the power supply, if they look ok try a new timing board.
Posted on Sep 13, 2021
  • garg_sanjay Sep 13, 2021
    Thanks Larry. Are there instructions or youtube video which I could look at to test out the voltage.
  • Larry Sep 14, 2021
    look on the power supply board for connector 801 there will be a legend on the board telling what voltages are at what pins, test each using frame as ground.
2answers
My samsung LTF320AP08 television shows black screen and then coloured vertical lines . It has volume but no image of channel
When a TV is showing vertical colored lines, a loose wire cable in the TV might be the cause. If you knock on the back of the TV, the vertical colored lines MAY disappear temporarily. This is a sign that a cable is loose or the T-Con board is faulty.
A black screen could just be a sign that the TV is turned off, although if it is producing sound then you know that's not the case. When your TV has a black screen even when it's on, it's quite possible it could actually be your external device and not your TV.
My Vizio TV has a bar of colored lines running veritcally over the picture. Should I replace the T-Con board?
What causes vertical colored lines on a TV screen? When a TV is showing vertical colored lines, a loose wire cable in the TV might be the cause. If you knock on the back of the TV, the vertical colored lines MAY disappear temporarily. This is a sign that a cable is loose or the T-Con board is faulty.
https://removeandreplace.com/2018/05/01/tv-has-different-color-vertical-lines-on-screen-how-to-fix/
Hi there I have a TV Samsung 46 inch model LN46B640R3FXZA It has vertical lines intermittently (more often than not) that slowly show up in different parts of the screen. Thank you Stami
Try cooking the tcon board in the oven...there are some postings on youtube that tell how to do it, if that doesn't help replace the board...Good luck!!
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
2answers
Plasma TV with vertical lines
EASY! ok the 4th video processing unit is malfunctioning, if it is a Piano affect like the keys on the piano, then that can be fixed under your 1year warrenty after your 1year warrenty it will cost $200, but i could be wrong, i never studied panasonic plasma casue they ****, next time get a samsung.
the worst contrast and video ajustments, thats a panasonic.
trust me i am the flat pannel guru!
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Televison & Video Logo
Ekse
Demonic-2011
Demonic-2011
