Question about Maytag Washing Machines
My top load Maytag washer performs won't restart after adding clothes
Posted by Barbara Larson on
Thomas Perkins
  • Maytag Master
  • 14,942 Answers
Try pressing the start button.
Posted on Sep 15, 2021
Maytag bravos, MVWB750YW0
Maytag is strong, durable and worth every penny. If I was buying another washer It would definitely be a maytag. They wash clothes thoroughly. Of all household appliances if have to have a maytag washing machine and my favorite vacuum cleaner.
Washing machines use a combination of water, detergent and wash action to deliver cleaning performance. Wash action is the movement of clothes provided by the washer during a cycle, and this can be different in front load vs. top load machines, as well as top load agitator vs. impeller models.
2helpful
We just moved and the house came with a Maytag Neptune TL which won't spin if there are clothes in the cylinder. It will spin empty. Please help! Thanks.
Washer bangs around in spin cycle and throws a DC or UC unballance code with cloths in the wash basket is that correct?
If so it's a Clutch issue.
If you want read more about what I feel is your issue read this post Maytag Neptune load unbalance
1helpful
I just purchased a Maytag centennial washer. I just love it the Maytag products arethe best. Question I am using the HE detergents as the book suggests, however how much bleach do I use?
According to page 6 of the manual for the "3 cu. ft. Capacity Maytag® Centennial® Top Load Washer" and page 8 of the manual for the "Centennial® High-Efficiency Top Load Washer", not more than 1 cup (250 ml) should be used in either machine.
Also, it should be added to the dispenser cup on the front left of the machine - not directly to the wash as it will interfere with the detergents ability to clean the clothes.
I hope this helps & good luck. Please rate my reply. Thanks.
Maytag Auto Load-Sensing Washer does not fill with enough water to wash the clothes. How do I get around this?
Did you ever get an answer - all I see are ads :-(
We have the same problem. Not enough water to rinse - even with extra rinse selected. Even our laundry comes out the color of the laundry detergent. I'm sure this is a result of government regulations to reduce water usage. We'll contact Maytag tomorrow.
My maytag neptune wash machine does not drain and spin clothes it
its ok dc means the clothes are unbalanced..even the load open lid and restart..onthejob
Maytag MAF1200AAW
WASHER MAGIC is the revolutionary product specifically formulated to safely and effectively clean the family washing machine. Top loading machine use whole bottle. Front loading use 1/2 bottle. You may rub Washer Magic on with a rag to eliminate odors.
Why Use WASHER MAGIC? Every time you wash your clothes, hard water and detergents causes lime scale and rust to build up inside the tub, pump and hoses. This build-up reduces the ability of your washing machine to perform. Mineral build-up acts as an abrasive increasing the wear on your clothes. The result: your clothes are not as clean as they could be and wear out sooner.
If you are unhappy with the way your clothes comes out of the wash, then WASHER MAGIC may be the solution you have been looking for. Only WASHER MAGIC can restore the family washing machine to the way it performed when it was new. Use once a month for optimal washer performance and to keep control of trouble causing build-up.
Washing Machines Logo
Top Maytag Washing Machines Experts
Jessie Goss
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
