Question about toner Office Equipment & Supplies
How do i fix Printer not recognizing new toner cartridge?
Posted by Ben patrick on
Don A
  • toner Master
  • 2,911 Answers
The following link has printer brand specific suggestions. This underscores the import of providing details such as brand and model of hardware when posting. https://www.tonergiant.co.uk/blog/2014/07/printer-not-recognising-compatible-cartridges/
Posted on Sep 13, 2021
I have change toner but same massage given
Then you still might have a bad toner cartridge. Try the following in the EXACT order:
1 Pull out the toner cartridge.
2 close the printer back up and let it recognize that there is not toner cartridge.
3 turn the printer oss
4 insert the new toner cartridge
5 turn the printer back on.
if the above fails you will need a new cartridge, preferably a different brand.
3helpful
I have printer canon lbp-2900 the problem is when i insert the toner cartridge in it the option apear on screen that no toner cartridge how i fix it send me best sulotion
Did you make sure that the new toner cartridge doesn't have a orange pull tab on the side. If that is left in it will make the toner not recognized by the printer.
1helpful
What do you do if the toner light comes on after you have installed a new toner cartridge
Did you remove the toner protect strip to allow the new cartridge to expose the toner?
Remove the Toner cartridge and reseat it. After reseating it, wait for the printer to recognize the cartridge, then turn the printer off, then back on.
AFTER RELOADING TONER INTO CARTRIDGES, THEN RED LIGHT BLINKING AND IT WILL NOT PRINT. WHAT CAN I DO TO FIX THE PROBLEM?
Did you change the chips in the cartridges after you filled them with toner? Inside the cartridges are chips that the printer keep track of the number of images that are printed. After so many pages, the printer marks the cartridge as empty, even if you fill it with toner. When the cartridge is changed the printer reads the serial number on the cartridge and keeps a log it its memory. If the chip is replaced, then the printer does not recognize it and thinks it is a new cartridge.
Hope this helps.
2helpful
2answers
Xerox 6360 will not recognize replacement toner cartridge
Only two things I can think of.
1 Be sure you have removed all the seals that are on a new cartridge. The tape etc. Sometimes a piece of one of them rips off.
If you have all the packaging seals removed then return the cartridge because its defective.
That machine can take up to 3 minutes to recognise a new cartridge. So if your turning it on and off quickly, let it set up for a few minutes.
HP Laserjet 3005DN toner cartridge change
You don't. HP printers seem to be very particular about this.  Take it back and get the exact replacment, including the brand.
1helpful
2answers
Printer won't recognize ink cartridge change
changed black K cartridge with new one but still shows black toner empty! Could toner cartridge be faulty?
LDell 3100cn awer printer won't recognize new toner
Have you removed the plastic protection strip from the bottom of the toner?
2answers
Toner cartridge end of life message
Go to the menu on the physical printer. Go through the selections until you see it say change print cartridge. Follow until you see to change the black one.
Top toner Office Equipment & Supplies Experts
NOEL
NOEL
ADMIN Canada
ADMIN Canada
ray gallant
Are you a toner Office Equipment and Supply Expert? Answer questions, earn points and help others
