Question about Xerox Office Equipment & Supplies
Xerox wc7845, line on print out
When i print in color mode, print out came with small vertical lines
Posted by Otto Nelson Komba on
Simon Atkinson
  • 2,260 Answers
It could be the print heads need cleaning. Depending on the model of printer you can either do a clean through the actual printer or through the settings on a laptop or computer that is linked to the printer.
Posted on Sep 13, 2021
  •  Otto Nelson Komba
    Otto Nelson Komba Sep 13, 2021
    tried to clean many times, after few copies same problem
  • Simon Atkinson
    Simon Atkinson Sep 13, 2021
    If it is a 'stand alone' photocopy machine the print heads might need a 'manual clean'. This will need a technician to remove the heads to clean them.
    Another thing to check are the ink cartridges. Cheaper cartridges, that are NOT Xerox, can be a thinner mixture and a poorer quality ink.
My Xerox 550 is printing some black lines all over, how do I solve this problem?
What causes black lines on paper when printing?
Usually streaks or vertical lines are caused by empty toner cartridge or toner itself is damaged. It's also due to a dirty pick up roller or paper path. You can contact HP Tech Support so they can replace your printer
Xerox workcentre 4250 vertical white line
This could be a developer tank problem. What colour does the white line show up in?
Investigate that colour.
Good Luck.
Xerox is printing pages with a red line down the left side
Streak in only one color:
Check the condition of the print cartridge, and replace as necessary.
Verify that the print cartridges (C/M/Y/K) are genuine Xerox cartridges,
and replace if necessary.
http://download.support.xerox.com/pub/docs/6180MFP/userdocs/any-os/en/user_guide_en.pdf
3helpful
Samsung scx-4521f xerox and printout taken a black vertical line appear on the paper
black vertical lines are generally an indication that the imaging drum needs to be replaced
This evening I bought a new HP Photosmart C4780 printer. I am trying to print photos now and the photos are being printed with small vertical lines across the whole photo. How do I get rid of them?
> I bought a new printer
Take it back, and get one that does work correctly.
> VERTICAL lines ACROSS the whole photo
Hold the paper in "portrait" mode, not "landscape" mode.
Are the lines HORIZONTALLY-ACROSS the paper,
or VERTICALLY-DOWN the paper?
If those lines are WHITE and HORIZONTAL,
then some of the many ink-jets inside the print-head are *CLOGGED*.
Run a "print-head-cleaning-cycle" to try to unclog it.
Or, exercise the WARRANTY, and get it replaced.
Vertical lines on screen different colors
The problem is the LCD panel or the logic PCB (printed circuit board). you can find the logic pcb attatched via flat ribbon cables or small plugs. Good luck. The part number should be on the printed circuit board. I hope this helps.
Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Xerox phaser 7760dx
This could possible be the magenta drum cartridge. also try cleaning the ROS assembly window below the drum cartridge.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
My Xerox 6130 keeps printing vertical pink lines on pages
your color laser printer pink vertical line appear on the roller and film drum,
1) you need check the pink drum surface, it got damage if you find there is a different color vertival line on the drum surface, so you need change the pink drum.
2) check the pink drum cleaner (call brush to return the waste toner), it can not clean well sometimes, if the drum surface good.
1helpful
Possible Print Head Issue
Select the Jet Substitution Mode.
  1. On the Control Panel, select Troubleshooting, and then press the OK button.
  2. Select Print Quality Problems, and then press the OK button.
  3. Select Eliminate Light Stripes, and then press the OK button.
  4. Select Jet Substitution Mode, and then press the OK button.
  5. Follow the Control Panel prompts to select the color and malfunctioning jet number indicated on the Light Stripes Test page.
Open Questions:
Top Xerox Office Equipment & Supplies Experts
Ekse
Joaquim Martins
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
