Computers & Internet Logo
B
Becky murphy Posted on Sep 12, 2021
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot find my network provider in Alexa app.
How do I add my network provider to Alexa ?
ADMIN Andrew
Level 3:
Top Expert:
  • Computers & ... Master 66,772 Answers
  • Posted on Sep 12, 2021
ADMIN Andrew
Level 3:
Top Expert:
Answers
66772
Questions
Helped
5048519
Points
378732
Link Your TV or Video Service Provider to Alexa
  1. Open the Alexa app .
  2. Open More and select Settings.
  3. Select TV & Video and select your TV or video service provider.
  4. Select Enable Skill and follow the on-screen instructions.
Link Your TV or Video Service Provider to Alexa - Amazon.com
How do I hook my used Alexa to WI-FI with my phone after down loading the App.
Question edited for clarity Alexi to Alexa.
To connect to WiFi:
  1. In the Alexa app, open the left panel menu and then select Settings.
  2. Select Device Settings.
  3. Choose your device.
  4. Select Change next to WiFi Network and follow the prompts in the app.
Amazon Echo Show/Echo Dot WiFi Connection & Bluetooth ...
Spectrum.net https://www.spectrum.net > support > internet > amazon-...
How to Connect Alexa to WiFi, With or Without the App
HelloTech https://www.hellotech.com > Home > Smart Home
To connect Alexa to a new WiFi network, open the Alexa app and tap Devices. Then select Echo & Alexa and choose the Alexa device you want to connect to a new ...
How to connect Alexa to your Wi-Fi network
Android Authority https://www.androidauthority.com > how-to-connect-a...
Apr 10, 2023 - To connect Alexa to Wi-Fi, open the Alexa app on your phone or tablet once your speaker or smart display is in setup/pairing mode.
Jul 23, 2023 • Cell Phones
My Amazon fire tv does not show on the Alexa app so I cannot some the two. B how do I add it
Your Alexa-enabled device doesn't connect to your Fire TV. Make sure that your Alexa-enabled device and Fire TV are registered to same account. Check that your Alexa-enabled device and Fire TV are on the same Wi-Fi network. Make sure that your Fire TV and Alexa app have the latest software version.
2answers
Why Alexa App Say Alexa Device Offline
Alexa device goes offline is not alert, but it shows not respond and then Alexa App say as "Alexa device Offline"
Now, you need how to fix the Alexa device's offline issue?
Learn to follow some instruction steps for solve Alexa Device offline.
You can check your Alexa device is in working condition.
All wire and device connections are in working condition and correct connecting in manner.
Wireless networking working active state.
Alexa device kept in Wireless network range and connection of Alexa device and wireless router through the same wireless network.
Use the same user ID registration on the Alexa device and Alexa App during Alexa Setup.
Alexa App is updated latest version.
Sometimes offline Alexa errors also occur due to dust particles on the Alexa device then you can need to clean the Alexa device in your daily routine.
If you have more information and Help then contact Alexa helpline today.
2answers
Connect alexa devices to new wifi
There's a button on the Alexa device that will put it in setup/pairing mode. Then you can connect to it on your mobile device. The Alexa app can then find it and prompt you in the app for the network and password you wan to use. Most Alexa devices will provide verbal prompts for these steps once you start the setup sequence.
I can not connect my new echo to my ipad.
Hi Barbara, do you have the Alexa app on your iPad? If not, you will need that. I am going to assume you have an Amazon account to link Alexa to? Once you first start the Echo it will go in to paring mode and tell you to open the Alexa app on your device to add the Echo to your account. The Echo will then attempt to join you home wireless network. The Alexa app should provide instructions on getting the Echo online. Hope this helps.
Can't seem to find where to a add light to a group in Alexa app (app version 2.2.2378)
You can only add a smart light in Alexa and only add which smart light is working with Alexa you can find out how to add when you got smart light the wright down in them booklet
7answers
Setting up echo dot
hi roger.
see if this helps you out.
  1. Turn on Echo Dot. Place your Echo Dot in a central location (at least eight inches from any walls and windows). ...
  2. Connect Echo Dot to a Wi-Fi network. In the Alexa app, follow the instructions to connect Echo Dot to a Wi-Fi network. ...
  3. Talk to Alexa. ...
  4. Optional: Connect Echo Dot to an External Speaker.
Amazon.com Help: Set Up Your Echo Dot
https://www.amazon.com/gp/help/customer/display.html?nodeId=201994280
or if you need more help go to this link.
Setting up echo dot Google Search
I just switched to a different internet provider. Alexa says she is having trouble connecting. What should I do?
You probably need to connect to your new wireless router.
Open the Alexa app.
In the Alexa app, open the left navigation panel and then select Settings.
Select your device and then select Update Wi-Fi. If you're adding a new device to your account, select Set up a new device instead.
On your Echo device, press and hold the Action button for five seconds. The light ring changes to orange, and your mobile device connects to your Echo device. A list of available Wi-Fi networks appear in the app.
Note: The Alexa app may ask you to manually connect your device to your Echo device through your Wi-Fi settings.
Select your Wi-Fi network and enter the network password (if required). If you don't see your Wi-Fi network, scroll down and select Add a Network (for hidden networks) or Rescan.
Optional - Save your Wi-Fi password to Amazon: Any Wi-Fi passwords saved during setup automatically appear when you connect a new Alexa device to the same Wi-Fi network. The password is also remembered if you switch between saved Wi-Fi networks. For more information, go to Saving Your Wi-Fi Passwords to Amazon FAQs.
Optional - Connect to a public network: Enter any required information if you are connecting to a public network that requires a web browser to sign in, like a school or hotel. The information could be a pre-shared password, room number, or just a button to accept conditions for using the network. This information cannot be saved to Amazon. Contact the network owner for more information.
Select Connect. After your device connects to your Wi-Fi network, a confirmation message appears in the app.
Grand Canyon Tech
Grand Canyon Tech
