Nuance n 200 connection to amplifier
Nuance n200 tower speaker connectio to amp
Posted by Trevor Swartz on
  • 3 more comments
  • Larry Ng
    Larry Ng Sep 12, 2021
    first tell all parts of the system all makers names and model number first if each part of system.
    endless answers possible for 6 decades.
    solid state, even older with TUBE amps, vast.
    we can not see over your shoulder, but you can post a photo of all that and we can play that game too.
  • Anonymous Sep 12, 2021
    how do i Nuance n200 tower speaker connect upto my secret not stated amp ?
    well with RCA cables, coax from amp'd speaker n200 to any amp or rig made with preamp out jacks same.
    there is no more simple answer than that.
  • Trevor Swartz
    Trevor Swartz Sep 14, 2021
    harmon kardon avr247 to nuance n 200
  • Larry Ng
    Larry Ng Sep 15, 2021
    OK WE NOW HAVE THE 2 FACTS NEEDED TO ANSWER THIS SIMPLE QUESTION.
    A 2007 AVR
    so here we go, the answer.
    I found your manual 1second flat, google
    I read it and in 10s
    then see rear panel words.
    and I see this. pdf page 10 rear panel view
    we want to use AVR L/R sound out, (not input) only outputs and those are called RCA jacks/plugs.
    bottom left is PRE amp outs. clearly lable and left and right both and center. and sub woofer.
    connect those 2 jacks to the 2 speakers, the speakers have there own built in power amps (PA)
    and have there own power supply to AC wall jack power. or the speakers will be dead, lacking power.
    that is how it works
    if one speaker is dead,(gee this old the amps fail) then switch left and right, side. if the bad one moves to the other side it is a bad amp in that speaker (inside it)
    bottom left rear.
    read. FR and FL, = front right, front rear , bingo this.
  • Larry Ng
    the manual to ARV above
    https://www.manualslib.com/download/6569...
    it is a beast, I have one too like here retired. now.
Larry Ng
  • Audio Player... Master
  • 6,089 Answers
That was a hard one, a not related to PCs topic about home audio sound music systems.(not told all parts)
and super rare only found in canada
and wow super freaky old, 2006?
but yah
speaker RCA jack goes to AMP/av/receiver/etc any made on earth, with RCA jack pre-amp out (coax cables)
if one side fails the amp deep inside that speaker is blown out, and is common)
the 1974 maker is now defunct, google hits = zero.
Posted on Sep 12, 2021
What to do if speaker connection does not work but the speakers are working on other connectios
Could you please elaborate on what devide you are talking about? are you talking about an amplifier or are you talking about a phone with a 3.5mm jack?
If you are talking about the 3.5mm jack, then the playback device is broken, otherwise the amplifier is broken. Both are difficult to repair and I need more information until I can help you with it.
I have 4 nuance N-300 amps that don't work. Where do I start?
Nuance Speakers Speakers ' Kijiji: Free Classifieds in ...
www.kijiji.ca > Alberta > Calgary
KijijiFind Nuance Speakers Speakers in Canada ' Visit Kijiji Classifieds to buy, sell, ... Usedcars, pets, jobs, services, electronics, homes, boats for sale and more ... 4 Nuancespeakers 1 subwoofer Rarely used Model N - 300 Asking $1000 OBO ... I have down sized to an apartment and don't really have room for a pair of these.
Common Car Amplifier Problems and Solutions ' Techlore
www.techlore.com/article/common-car-amplifier-problems-and-solutions
Many car amplifiers are incorrectly diagnosed and sent in for repair/returned .... but my back two interior speakers still play music/whereas my front speakers don't ... I getsound n everything from my subs but I get some really nasty bass like if the .... I havea JL Audio amplifier 300/2 that I had on my truck , it turns on but gets ...Missing: nuance
2answers
No sound out of tower
Try different inputs. Connect your output to a different amp to check there is a signal there. Sorry to suggest this but often it's a simple solution, check carefully that all controls - volume etc - are turned up enough. Check the two parts of the tower and where it connects to the base are connected properly
I've got a nuance home stereo self amplified sub
A electronic perts supply store, Like radio shack or the scorce.
2answers
I've just been given a Wharfedale S-990 Amplifier, Tuner CD etc tower - but without any speakers. Output is 2x50W - but the impedence isn't specified. I'm just looking for advice on what...
Anything in the neighborhood of 8-ohms will usually fly safely with standard audio amplifiers. At only 50w x 2 you want efficient speakers. Watch the volume as this amp may clip if driven too hard. THAT will kill any speaker.
This owner had Valdus 200's and was happy. But just about any quality speaker in the 100w range should work out.
http://www.avforums.com/forums/hi-fi-systems-separates/368695-wharfedale-s990-any-good.html
1helpful
The system worked fine but has an intermittent connection in the main power tower unit..you can shake the unit or bump it heavily and the sound from the main tower speakers goes and comes with a lot of...
They are prone to bad solder connections on the power regulators and output ics. should only be a labor charge. est $60 -100
Not very easy to take apart, need to remove several screws on rear of unit, remove front grill remove some screws on front. disconect connectors remove amp and power supply board, resolder bad connections and re-assemble. I've done several would take me 30-45 min.
Multi amp hook-up
honestly i dont think those to amps will push cvxs no matter how you wire them up.
the rms on the 200 should be used to push a door speaker.
the 800watt should deff just be hooked to 1 cvx but still wont max it out.
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
6helpful
2answers
Subwoofer Module N-200 ( Nuance ) Short on circuit board
I'm working on a guys board looks like it is the Q10 and Q1 transistors I'll let you know how it goes.
Ekse
 Grubhead
Grubhead
