Question about Fisher Washing Machines
Fisher & Paykel toploader - drum leaning towards the right.
The machine just stopped mid cycle and I can see the drum is off balance, leaning towards the bottom right. It looks like the red spring is still attached, the legs are on evenly and the machine is on a tiled, flat surface. Any ideas how I can fix this? Have removed the clothes and water. The machine always sounded as though it was going to explode when it was doing its spin cycle so thinking it might have come off something?! It is at least 10 years old I would say but was working fine before this. thanks
Mazin Al Haddabi
There are 3 to 4 spring assays that holds the drum from inside that need to be replaced every 2 to 3 years of using.
ask the dealer for replacement parts and you can replace the assays by yourself easily by leaning the drum to one side and unhook the spring assay from the top then push it downside gently to unhook it from the bottom. Do them one-by-one and don't unhook all of them at once.
hope this would help you
Posted on Sep 12, 2021
Testimonial: "Thank you very much for answering, this is very helpful!"
  • Joanne Benally
    Joanne Benally Sep 16, 2021
    My Boy pal makes $seventy five/hour on the internet. She has been without an assignment for six months however in the remaining month her pay has become $16453 genuinely working at the internet for some hours. immediately from the source.............www.smartcash1.com
How to clean drum in fisher paykel washing machine ? Also why so noisy and moving across floor on spin cycle?
bowl out of balance
bowl not level
check for suspension bolts and insulators holding the bowl level
What does it mean when my fisher and paykel washing machine stops mid wash cycle and starts beeping the lights that show up are 2 and 7 it's a gw611 model
I would normally say a clothes balance issue but if its happening all the time. u may have an issue with the counter balance weights or rods depending on ur type of appliance. If they go bad they tend to shut down applaince mid cycle after some amount of movement or shaking. and what happen is it contantly throw machine into unbalance position
Fisher and paykel kelvinator II smart drive 501 washing machine stops washing mid wash
Check the out of balance switch under the blue motor controller
for corrosion replace if corroded.
Why would it stop mid cycle? You can hear the engine trying to start.
It is not the engine but the motor that makes the noise. perhaps it can be a mechanical issue that stops the machine at mid cycle due to friction on the drive or it can be due to faulty control panel or even a dirty/ clogged drain pump.
Dryer not providing any heat during cycle
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ Check posts on "Heaters" in this forum will work you through your problem
Fisher paykel washer has on occassion left grease on clothes
it is unlikely its coming from the machine rather some you put in there,try a short hot wash with strong detergent,no clothes
2answers
Fisher & paykel mw511 pride
Check the pipes actually work first. Is there a hidden drain filter that is partially blocked? Dissasemble the pump and check it works and the blades inside are clean.
Stops mid cycle
It may be a out of balance alarm during a spin cycle. Re-balance the clothes and hit start.
Stops mid cycle
CHECK DRAIN PUMP AND DRAIN HOSE FOR RESTRICTION
Washing Machines Logo
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
