Question about PRINTER Office Equipment & Supplies
How do i fix Printer Machine Error 6A? - PRINTER Office Equipment & Supplies
Posted by Ben patrick on
Fred
    Top Expert:
  • PRINTER Master
  • 34,958 Answers
Depends on make and model plus what your OS is and router settings.
Posted on Sep 11, 2021
How do I fix Machine error 6a of my Brother Printer?
This error happens when the lamp of the printer fails to sustain a certain temperature within a time limit. You can fix this error by manually entering the mode of maintenance. You can press menu for entering into the mode and then focus on the display; if it is done rightly, the light will start to blink.
https://medium.com/@johnshort3190/how-to-easily-fix-the-brother-printer-error-code-6a-c78e91e789fc
Machine error 6A
Fuser Thermistor or Halogen lamp defective. maybe you need to replace the whole Fuser
I have a Brother DCP 8020 Multi printer. Im getting machine error code A6. After replacing the fuser
This is what is written in my service manual for Error Code A6:
Error code 6A
Print Unable 6A
Turn the power off and then back on again.
Fuser unit failure (The side thermistor does not detect 60degreesC within the specified time.)
Reset fuser
Hello -
This is a good question.,. and you have got me stumped! What I would do is contact the manufacturer's tech support line, they would be far better suited to provide a more accurate answer...
Best regards,
Ck
WHEN I TURN ON MY MACHINE BROTHER MFC 8440 I SEE ON THE SCREEN ERROR MACHINE 6A I NEED A SOLUTION
Error factor: Heater warming-up timeout error.
(Heater does not reach 60°C within 11 sec.)
Check: • Thermistor ASSY
• Halogen lamp
12helpful
3answers
Machine error code 6A what that means?( Brother mfc 8440)
I argued on the phone with a BROTHER REP. that he should give the codes and directions to reset the machine, he refused time and time again, saying that this means physical damage to the machine an re-setting it is impossible to help, but i insisted, and it did fix the problem and the error went away.
here is what you should do, unplug for 10 sec. press and hold on the menu key while you plug it back in untill you see the screen "parameter init" press 99 and wait, this is what i did and it fixed the problem !!
5helpful
2answers
Machine error 6a Brother 8840D
1) Unplug machine.
2) Hold down menu key while plugging in machine.
3) Enter 99 while holding down menu key
4) After it says "PLease wait" hit the stop/exit button to get out of the maintenance mode
3helpful
Top PRINTER Office Equipment & Supplies Experts
Pcm2048
Are you a PRINTER Office Equipment and Supply Expert? Answer questions, earn points and help others
