Question about GE Washing Machines
Capacity of GE model WWA8330BAL
Trying to get the cubic foot tub capacity of this large capacity model that we no longer have, but would like to (try to) match.
Posted by Gregg Phillips on
ADMIN Canada
    Top Expert:
  • GE Master
  • 40,079 Answers
Capacities are 3.8 cu.ft or 4.2 cu.ft for the largest
https://www.google.com/search?q=Capacity+of+GE+model+WWA8330BAL
Posted on Sep 10, 2021
  • Gregg Phillips
    Gregg Phillips Sep 10, 2021
    Thank you!
  • ADMIN Canada
    ADMIN Canada Sep 10, 2021
    You are very welcome. I tried to find the exact specs but couldn't. It must be an old machine.
    https://www.google.com/search?q=GE+WWA83...
I am trying to find out how many cu ft my Kenmore Elite HE 4 dryer is. It is no longer made & is not searchable on any sites. The model # is 85089400
7 cubic ft. capacity.
Measure the diameter of the tub using a measuring tape
  1. Divide the diameter by two to get the radius
  2. Measure the height of the tub in feet
  3. Multiply the square of the radius with the height of tub and pi (3.14). (square of radius x height x pi)
The result would be the capacity of dryer in cubic feet.
Washing machine - 261/2 x 43 x 28
Outside dimensions don't account for cubic ft because inner tubs are round. You need the model number and input it into google search or look it up on GE.com. GE uses same cabinet on most washers but has different inside capacity on top loaders.
Need personnel Capacity for 1989 Wellcraft Sportsman 250.
go on line to google -type in seating capacity of wellcraft 250 and under southport-freedom boat club you will see a passenger capacity --6
Do I keep my old Kitchenaid extra capacity or keep the new GE GTWP1000
The GE has a capacity of 3.3 cubic feet. You did not list the model of the kitchenaid. Make sure the GE was stored correctly because if it might have lost oil or gotten brittle belts or gaskets. Also it might have frozen.
I have a gateway dc-t50 camera and replaced the 32mb sd card holds only 12 pica to a 4gb sd card and getcard error message ?
Your problem is in trying to mix and match old and new technology.
Your camera can handle SD cards up to an absolute maximum capacity of 512MB (as per page 21 of the user manual). It's incapable of operating with anything of a higher capacity and totally incompatible with the SDHC card you appear to be trying to use.
Your only fix is to either limit yourself to 512MB maximum capacity SD cards, or to replace the camera with a modern SDHC compliant model which will accept your new card.
I hope that you have found my free reply to be clear and useful and that you can take a brief moment to rate my answer.
1helpful
2answers
Walking ge super capacity plus washer
the drum straps are probebly broken just remove the front then remove the 2 1\4 inch screws that hold the top on remove the top the straps are located on top of the tub they are black rubber
2helpful
I have a Kenmore 70 series washer Model 110-20722990. I am trying to find out what kind of tub is in it (plastic or steel) and the capacity. I don't see this info on the washer anywhere. Thanks!
ceramic coated steel tub - 3.2cu ft capacity.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Michael Thomas
Michael Thomas
Gerry Harvey
Gerry Harvey
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
