Question about Casio Office Equipment & Supplies
Casio FX-9750GII showing decimals with letter E
I've pressed [SHIFT][SET UP], Found Angle then set it to Deg. Its still showing, for example, 0.001^2 as 1E-06 which, even though is correct, is the format that I want. I want it in decimal.
ADMIN Canada
    Top Expert:
  • Casio Master
  • 39,931 Answers
Here is the manual, or reach out to Casio in the country you reside.
http://graphic-technologies.co.nz/doc/FX9750GII_Manual.pdf
Posted on Sep 10, 2021
The words FIX DEG appear on the screen and I can't get rid of it. It doesn't calculate properly
DEG says that the angle unit is set to degrees. You can change it to RADians, or GRADs. However much you want to get rid of all of them you will always have one of them. Learn to live with them.
FIX says that the decimal displays will always show a fixed number of decimals. You can decide how many you keep. Apparently your calculator is configured not to show any decimal digits: the number of fixed digits is set to zero. Change it to some other number
There are other display formats : Engineering ENG, and Scientific (SCI)
There is another format (possibly 2) called Norm 1 or Norm 2.
Set you calculator to one of the Normal formats.
Press SHIFT MODE to enter (Setup) and configure.
Advice: Learn to use your calculator. The best way to achieve mastery is to look inside the manual whenever you do not understand something.
Scientific notation on the casio fx-9750GII
We need verbs (actions) in your questions and interrogative pronouns too. Anyway, to have a numerical result displayed in scientific format, you must set the display to scientific. You must specify the number of decimal digits to keep.
To set the display format, open the Run>Mat screen. Press [SHIFT][Menu] to open (Setup). Scroll Up to reach the line Display, press [F2] (Sci), type in the number of decimal digits, press EXE. See the screen captures below.
1helpful
My tangent is lower than the real tangent number on Casio fx-9750gii
The tangent of 60 radians is about 0.32, while the tangent of 60 degrees is about 1.73. To change the angular mode, press SHIFT [SETUP], down-arrow to the "ANGLE" line and then press the function key corresponding to the desired mode.
Changing sin cos tan to degrees
Press SHIFT SETUP, use up/down-arrow to highlight "Angle," then select "Deg."
How can i convert my calculator from degree to radian?It shows radian now, But i want degree... I know there is a step can change the calculator data. but i want to know what is the step. My calculator is...
  1. Turn calculator on.
  2. If you see no icons, press the[ MENU] key
  3. Highlight RUN/MAT and press [EXE]
  4. Press [SHIFT][MENU] to access (SetUp)
  5. Pressing the down Arrow 5 times move the highlighting to the line ANGLE.
  6. At the bottom of the screen 3 Tabs appear.
  7. Press [F1:Deg¸]
  8. Press [EXIT] to return to Main Run/Mat screen.
11helpful
I have a Casio fx-9750GII, how do i switch my radians to degress?
From the Run Mode (select it and press exe), enter Setup (Shift Menu) and then highlight Angle. Press the function key that correponds to Deg and then press Exit.
The manual for the Casio Fx-9750GII is here: http://support.casio.com/manualfile.php?rgn=1&cid=004002013 . Other calculator manuals are here: http://support.casio.com/manuallist.php?rgn=1&cid=004 .
I hope this helps.
2helpful
Can't find angle measurements function on casio fx 9750
In [RUN], screen press [OPTN][F6:->][F5:ANGL] [EXE].
Exemple 18.53 deg
18.58 [F1 Degree symbol] [EXE] shows 18.58. At the bottom of the screen appears a new option DMS with a left arrow. By pressing the corresponding key [F5], the screen displays 18 deg 34 min and 48 secs. To enter an angle in DMS, exemple the one above, you procedd as follows:
18[F4]34[F4] 48 [F4] [EXE] displays 18.58
Hope it helps.
6helpful
How do i display decimals on casio fx 115es
The instructions are below the screen. It says Mode arrow and a table of numbers.
If you want to set (use) degrees, you press the MODE key followed by the 4 key. On the top of the screen deg will be displayed.
If you want to set RAD or GRAD, similarily, you press MODE followed by 5, or MODE then 6.
However if you want to convert a result displayed in a particular unit into other angle units, you press SHIFT MODE then 4 or 5 or 6, whichever is the case for you.
Hope it helps.
1helpful
Problem with Casio FX 260 Calculator
Read the screen capture about the MODES of this calculators. DEG,RAD, and GRAD remind the user that the angle units in trigonometric function calculations and coordinate conversions are in degrees, radians or grads. They have nothing to do with the other calculations you are doing.
You can only remove DEG by changing the angle unit to RADians or GRADs. In so doing, the new unit indicator (RAD, GRAD) will be displayed instead. There is no point worrying about the angle unit indicator unless you are performing coordinate conversions or calculating trigonometric functions or the inverse trigonometric functions.
MODE 9 cancels the FIX display format: decimal are displayed with a fixed number of decimal places (set by the user). After this key sequence the decimal display format reverts to NORM(al).
Top Casio Office Equipment & Supplies Experts
k24674
Ekse
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
