Question about Frigidaire Washing Machines
Frigidaire Stack Unit. Model # FFLE1011MW2 Wash cycle seems to go endlessly, will not advance... will not drain/spin. Any advice?
Posted by Tom Marthaler on
ray gallant
    Top Expert:
  • Frigidaire Master
  • 73,512 Answers
SOUNDS LIKE A BAD TIMER
Posted on Sep 09, 2021
Washing machine will not spin
Possible that the program controller is not advancing to the next level and so the sequence to the levels must be checked with a multimeter.
check the cycle after the first wash and drain and if this does not proceed then check the drain and also the program controller unit.
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
2helpful
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
My GLTF1040AS0 front load washer has stopped advancing after the wash cycle.
Does the unit stop and display any error code(s)? Is it noisy in Spin? If yes to either your pump drain screen is likely cloged/restricted and the pump itself could be damaged.
AND/OR
Drain hose is pushed to far down into drain stack. This can cause a syphon effect were water drains while the unit is filling.
Water runs during final spin cycle
You have a blockage in the drain pump. Remove the front panel to access the drain pump.
Bail the water from the tub.
Remove the hoses on the pump and clean out the lint or garment from the pump.
7helpful
2answers
Washer does not spin after wash cycle
Problem solved. It was one of the resolutions posted by one of your clients. TKS. PS this one of the best problem solving sites that I have seen. Great Job Rick
Frigidaire gallery stack wash/dryer
Sounds like it could either be a bad solenoid in the fill valve or a bad pressure switch...both issues are easily repairable.
LTF2140E Front loader washer
My Frigidaire front loader washer model LTF2140E doesnt want to drain the water when set to wash (heavy-normal-quick selectors). It washes put thats it. I have to switch the selector to drain/spin then rinse/spin cycle to finish the load. I checked the drain hose for any clogs....everything is clear. Any suggestions? Also,iIs2.gif their any reset buttons for this type of washer?
Open Questions:
Washing Machines Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
