Question about Hisense Televison & Video
Hisense 58R6E no sound no picture?
Hisense 58R6E power light flashes red twice, can see logo on screen with flashlight then tv shuts off. How do I test power supply and led strips? 3rd time asking because it keeps getting removed
Posted by Kyle Marshall on
Larry
  • Hisense Master
  • 3,157 Answers
This model had a lot of backlight issues with the lamp strips being bad, order a new set and install them and it will work again, but be careful handling the panel, it's VERY fragile
Posted on Sep 08, 2021
1helpful
3answers
Hisense 55R6E no picture /no sound
This model set had defective LED lamps from the factory and only lasted 1000 plus hrs...You can get lamps that will last from shopjimmy that will fix the issue for about $60 with shipping. Its not a hard job changing them, just takes some patience and care when handling the screen as it's extremely fragile on most lower price sets.
1helpful
Will the LED backlights glow even when one LED is not working?when i switch ON tv,the toshiba logo displayed for a second and then it goes off.Flash light test on black screen shows images though.
I don't know your TV but are you sure that it is an "LED" TV? If not, it may be an "LCD" TV which is a bit different. An "LED" TV uses Light Emitting Diodes to illuminate the individual pixels or PIcture ELementS. If it is an "LCD" TV, the picture works more like an electronic digital watch. The picture is produced within the screen and uses a florescent tube on the bottom and side to back light the screen. If you can see the picture with a flashlight, I suspect that it is an "LCD" type. If it was an "LED" TV, and it didn't light up, the LED's that make up the pixels wouldn't be firing and you wouldn't be seeing a picture even with a flashlight. Just like any florescent light tube, these "LCD" back light tubes will dim with age until they eventually fail. If the Toshiba logo lights and goes out, this sounds like the bulbs or their high voltage drivers are failing. Good luck.
Toshiba TV, sound works but no picture I have a Toshiba 49L621U. It was made in September 2016. When I turn it on, I see “ Toshiba” in big bright red letters (normal startup image) than the TV goes black....
Same issue here. I kept plugging in the TV and it would flash the logo and go black. I disconnected the LED line from the power board, plugged the TV back in and the LED's all lite up and got great picture. Turned it off and on a few times with the power switch with no problem. Left it alone about an hour, came back, got the same symptoms all over again, Flash then nothing.
I changed out the Power Supply board....same issue, Flash of logo and black screen. Probably going to heave ho the set.
I have a Hisense led tv model F39V77C.
Yeah, replace the set since it appears to be trashed. But if you have a few bucks lying around you might want to try replacing the unit's power supply to see if that resolves the many issues you have.
2answers
On my Hisense 50K23DG LED TV, I have sound but no picture.
LCD & LED TV Repair - No Image & Blank Black ... - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen CLICK HERE to BUY ... I have an LG ...
Hisense 50K360G has audio no video will not turn on logo ...
? 1:48
https://www.youtube.com/watch?v=xI3MpZukKm0
Nov 20, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http://bit.ly/ShopJimmy6 Want to ...
All comments on LCD & LED TV Repair - No Image & Blank ...
https://www.youtube.com/all_comments?v=xUzCLgoSPGM
I have sound and picture but no backlight. .... how do you replace the back lighting on a led lg tv? ... I have a 42 inch LED LCD combo DVD TV made by RCA.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - Hi, I have an RCA 32" LED 1080p TV that is less than 2 years old, and it has already lost the video. I can hear sound, and I can see lights in the ...
53 HISENSE complaints and reviews @ Pixxed Consumer
hisense.pissedconsumer.com/
1helpful
Hisense LED HDTV
I am no expert, but I would be looking for a replacement or warranty on that unit.
Unfortunately there is very little an every day user can do to fix a problem like this on their own.
Televison & Video Logo
Top Hisense Televison & Video Experts
Jean Sintulaire
Ekse
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
