Question about Vizio Televison & Video
Model d70-d3. What caused backlight failure?
Impacted by a power surge. Backlight is not working but I can see the LEDs working if I put a flashlight on it.
Larry
  • Vizio Master
  • 3,170 Answers
I'm not totally sure what your asking, does your backlights work or do they not?...you said backlights not working but you can see the LED's, the backlights are the LED lights, or are you calling the LCD diodes in the panel the LED' backlights?
Posted on Sep 07, 2021
1helpful
2answers
How do i fix my smart tv
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board . In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
http://electro-medical.blogspot.com/
I have a vizio 70 inch tv and no picture but sound.What part should i replace
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
What component or components need to be replaced to fix the tv?
Try replacing the inverter board which powers the backlights on set.
If there is a power issue, will a faint light come on at power button and then get blue screen?
Hi, You will have to take the back off and look at the main power board. Make sure the plug is out when you do this. Look at the capacitors. If you are not teck savy get help.
When cost of parts ar more than a new TV then go buy a new TV.
Good luck.
2answers
Vizio E701i-A3 black screen
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Vizio will not power on, vizio emblem is off.
Did you check the power cord of intermittent connection.
2helpful
Suddenly no picture only a black screen.The tv has power the little vizio turns on white i can hear the audio and change through the cable channels with my comcast remote.The vizio remote will turn the tv...
Look through the ventilation slits at the back of the TV with the room lights out. If you do not see white light light bleeding through the back, you have a back light failure. It could be the inverter circuit which lights up the CCFL ( cold cathode fluorescent lamp ). You will need professional help to replace it and could cost you about 70 to 100 $ to fix.
Televison & Video Logo
Top Vizio Televison & Video Experts
Ekse
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
