The instructions and different (TV,VCR etc) brands and their respective codes are
http://www.sentryindustries.com/pdf/instructions/RMC10_Instructions.pdf
you must reset the code again use the code from your instr. manual. and proof again. Retight the spring contacts battery with pliers for a good contacts 2) clean the contacts battery. 3) resolder the wires contacts battery God bless you
Hold the code search button until the light stays lit. select the function your trying to program "tv" press the power button repeatedly until the tv shuts off.
the following is a link to the updated code list for the RMC-10, note it is in pdf format so if you do not already have adobe acrobat reader you will have to download that before you can read the code list. I will also leave the link to download the adobe acrobat reader in case you need it
I was able to get my Motorola DVR Cable Box to work with my Universal Remote using the following instructions:
The Instruction Manual for Manual Code Search seems incorrect. (Page 5).
A) Manually turn on the device to be controlled. (O.K.)
B) Press and hold the code search button until the red indicator stays on, then release the code search button. (O.K.)
C) Press and quickly release the desired mode button (TV, VCR). The red indicator blinks off once. (O.K.)
D) Face the remote control directly to the device you want to control. (O.K.)
E.) Press the ON/OFF Button (this should read CHANNEL UP button) repeatedly until the device to be controlled changes channel. The red button blinks off with each button press.
F) Press and release enter to install the code. (O.K.)
-Note, the remote is able to change the channel, however, it does not control the volume.
