Hi alpha saidyleigh, we want to help you with your question, but we need more information from you. Can you please add details in the comment box? you might have a space at the end of the document that goes into the next page is this the case here ?Hi alpha saidyleigh, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
You can't post conmments that contain an email address.
there is a small flag sensor in the output tray over the roller that deliver the printed paper , its not return down after paper get out. so the the printer scene the tray is full , check it may lost if not try to lubricate the support pour it hasn't spring it move to its weight. or it may
the white ghost lines are down to the charge wire within the toner cartridge being dirty, the only real way forward is to replace the toner cartridge as access to the charge chorona wire is not possible without ruining the cartridge itself
This has to do with the document printing properties. When you are ready to print a document, choose properties and make sure you go through the printer settings under that software. The test page only verifies the cartridges. The printer properties of the software control the printer during printing.
White lines are generally caused by clogged print nozzles. I assume that you have a printer with the print heads built into the cartridge. Are you using high quality cartridges or cheap refills? If cheap refills, try a better/different brand of cartridges and see if that helps.
I would also check the printer manufacturers website and try their recommended printer nozzle cleaning procedure.
make sure you check and make certain there are no scratches clean both the top of the scanner and the scanner bed itself and wipe down with a lint free cloth
