Question about Rotel Audio Players & Recorders
Manual circuit diagram
Rotel RA-810A
no service manual
Posted by terrydaniell on
Anonymous
  • 4,234 Answers
I don't believe that Rotel service manuals are available outside of authorized service centers. Can you provide us with the problem that you have? Perhaps we can guide you through the repair.
Thanks,
Dan
Posted on Sep 21, 2009
If we are measuring Ra value in multi time in a same place then every time Ra value become different. why this happen ?
At www.reliable-store.com has books on every vehicle and also how to service/repair it.
service/repair/owner's/maintenance manual with
parts info, fuse box, gear box, PCV, torque specs,coiling, wiring diagrams, electrical diagrams, fuse diagrams, error codes, etc everything
Worth it
Esquema electrico de pedal g1 zoom
Circuit Diagram - Zoom G1 Service Manual [Page 15]
https://www.manualslib.com > ... > Service manual
Zoom G1 Manual Online: Circuit Diagram. A MAIN PCB(PCB-0169) CPU Circuit - 15 - 5 6 7... ... Circuit Diagram - Zoom G1 Service Manual. Guitar effects pedals.
2helpful
Rotel RA 12
I think RA 12 is not existing type, but RA 12xx types exist.
Please try this link, and I hope you will find the relevant documentation.
gylacz
My Rotel RA-935BX blows out the fuse on the power socket during operation, after repair the fuse, it is blow out as Rotel power on, what's wrong?
It seems you have a short circuit in your unit. Further attempts at switching it on are not advisable as more damage will occur. Get it checked out by an electrician who can test from the plug for a short circuit.
2answers
2answers
Are you able to provide a circuit diagram or even a service manual for stereo integrated amplifier Rotel RA-350? The local service group said ''the problem is on the circuit board'' and eturned it unfixed....
Unfortunately schematics are not availabel for these units outside of authorized service centers. Where are you located? Any local shop that works on audio should be able to fix this as the design is relatively straightforward.
Can you also post the problem you are having with the unit?
Dan
Problem with Rotel RA 870
Since it is a Rotel, it is a good unit and worth fixing. At this point, you need to take it to a good repair shop and let a qualified tech look at it. There are no user serviceable parts inside and if you go poking around in there, you WILL make the problem worse. Rotels' are nice units and represent a good value in stereo gear. Take it to a reputable repair shop that repairs Rotel under warranty. If thats not available to you, then a good repair shop should be able to get you going. Good luck...Rob
2answers
Rotel Amplifier RA-9808X
Instead of replacing you can try and clean it. There are a lot of good contact cleaners out there.
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
