How many fans does a Mitsubishi qd82840 have?
ADMIN Canada
    Top Expert:
  • Televison & ... Master
  • 40,381 Answers
More than one! Referred to in the manual as fans. I would guess two. One on the lamp and one on the boards.
Manual
https://d1vofmza27mmhi.cloudfront.net/product-pdf/mitsubishi-wd82840-installation-use-and-care-guide.pdf
Posted on Aug 29, 2021
Larry
  • 3,308 Answers
Two
Posted on Sep 25, 2021
Mitsubishi timer light 6 times blinking
Indoor unit indicator
RUN lamp = 6 time flash
TIMER lamp = Comes on
Outdoor unit indicator (LED5) = Stays off
Description of trouble = Indoor fan motor error (2)
Cause = Defective fan motor, Connector poor connection
Conditions of flashing = When air conditioner is operating and indoor fan motor is turned ON, indoor fan motor speed of 400 rpm or under continued for more than 30 seconds. (Air conditioner stops.)
Mitsubishi Galant 2005 4dr blower fan has no power
The radiator fan will not normally have power. It is only when the engine coolant thermostat detects high temperature it sets on the fan relay which starts the fan. So it is likely the thermostat or the fan relay are faulty.
1helpful
Ac/heater fan does not work on 96 mitsubishi eclipse
unplug power wire to fan under hood turn key on and fan on high take piece of insulated wire trim insulation off of ends touch to fan where u unplugged it touch other end to positive on battery if fan does not come on then fan is bad
3helpful
Cooling fans are not running 2001 mitsubishi
Check if your fuse is blown! If not have the wires tested that run into your fan if there ok and show power then your fan needs replaced! Please give me a thumbs up if this helped! Thanks
Electrical chasis cooling fan for Mitsubishi wd 52525
There are several Parts Houses that carry this part. The one I think that is the easiest to deal with is Andrews.
The URL is:
https://dealer.andrewselectronics.com
Can't find it there, reply to this post and I will respond.
Televison & Video Logo
Top Televison & Video Experts
Ekse
