Question about The Optics
What are the settings -, o,+ for on my 10 x 42 28 1043 binoculars for
Bausch & lomb binoculars 10 x 42 , 28 1043 have a setting on the right side that are adjustable - o + what are they for
Posted by Krisa Farrington on
Tony Parsons
  • The Master
  • 6,343 Answers
To adjust the eyepieces to accommodate variations in your individual eyes - look in the manual.
Posted on Aug 24, 2021
How do I find eyecups for Bausch and Lomb 8x24 binoculars
Any sporting goods store that carries that brand should be able to get you replacement cups. Otherwise the Bausch and Lomb website should get you to the right place.
Aug 23, 2014 • Optics
Left lens fogs up
Binoculars are normally purged of air and filled with Nitrogen to prevent this. Each side is done individually. It sounds like a seal has leaked and it needs to be replaced and refilled.
2helpful
My discover binoculars have a double vision. They used to work fine. Are they repairable? Where?
Contact Bushnell, who was the manufacturer of Bausch and Lomb binoculars. They can service them for you.
Contact number for Bushnell is 800-423-3537.
Ben Lizdas
Sales Manager
Eagle Optics
www.eagleoptics.com
Seeing double image . baush and lomb custom 7x32
The binocular is out of collimation. They need to be sent to a qualified binocular repair outfit that can return the barrels back into alignment.
1helpful
Lens fogged up on inside of bausch and lomb elite
there's been some sort of breach in your casing. either a crack in a les, or maybe in the housing, perhaps it was dropped. if you can't take it apart and dry out all the moisture, you'll probably have to have it replaced.
1helpful
My 15-year-old Bausch & Lomb Elites need a slight alignment adjustment and maintenance. Where and how do I go about using the lifetime warranty? Thanks!
Unfortunately warranty wouldn't cover this. The warranty only covers manufacturing defects. Binoculars may come out of alignment over time as things get loose with age and usage. Bausch and Lomb owned Bushnell. Made binoculars under noth names. Since yours were made B&L sold off the binocular business to a venture capitol company and they too sold it to another the current owners. Elite is still a model name being made by the current Bushnell. They may undertake to do the service you require but at a cost.
The elites are a very good unit and well worth repairing or servicing.
Aug 06, 2009 • Optics
2helpful
My binoculars need some maintenance, and it looks like the eyepiece coating is wearing off. Where can I send them for repair, and do they come with a lifetime guarantee?
Bausch & Lomb binoculars did carry a Limited Life Time Warranty. I quote the first paragraph of the enclosed warranty card. The rest of the card just mentions the address to send them. The card is old and always good to check for the current address. "Your Bushnell or Bausch & Lomb binocular, riflescope, or telescope is unquestionably warranted to be free of defect in material and workmanship for the lifetime of the original owner." Coating wearing off is not considered a warranty repair as coatings can come off over time. Rubbing too hard often or not blowing off debris before cleaning can do this. Using cleaners not made for coated lenses also can. The Bausch & Lomb Discoverer was made by Bushnell. They have owned B & L's binoculars business since the mid seventies. Bushnell still make the discoverer line under the Bushnell brand name. Contact Bushnell in your country for service.
1helpful
Bausch and Lomb rubber eye cups
Bausch & Lomb was purchased by Bushnell in the 70's. Your elites are Japanese made and considered quite a good binocular. Bushnell continued to make the same binoculars bearing the Elite name but replaced B&L with Bushnell. The current elites are different shaped. You could contact Bushnell or you could go to a store in your area that may stock the older Bushnell Elites and try and see if the eyecups fit.
Optics Logo
Top The Optics Experts
Vernon Taylor
NOEL
NOEL
Are you a The Optic Expert? Answer questions, earn points and help others
