Coffee Makers & Espresso Machines Logo
Question about Bunn Coffee Makers & Espresso Machines
Why won't the reservoir on our Bunn My Cafe MCR (44600.0000) fit into the machine anymore?
Our office has a Bunn My Cafe MCR (44600.0000). The top water reservoir will no longer fit onto the top of the machine. I am unable to find a diagram of it to see of we are missing a seal or something along that line. Please help!
Posted by Genevieve Worley on
ADMIN Andrew
    Top Expert:
  • Bunn Master
  • 57,240 Answers
  • Genevieve Worley
    Genevieve Worley Sep 20, 2021
    I called Bunn commercial support and they could not help me. The reservoir should just sit on the the top of the machine, but for some reason the area where the check valve is will no longer fit down where it is supposed to. Nothing is missing, broken, or cracked. It is so strange. Any ideas?
  • ADMIN Andrew
    ADMIN Andrew Sep 20, 2021
    On the schematic on the bottom right, there appears to be a pin on the back of the machine. It looks like a locking pin that is inserted after you put the reservoir on top.. I find it dishonorable that the company that makes it won't help.
    https://commercial.bunn.com/44600.0000
    Here is the manual which I just read and it says it just lifts off. It is very odd. I would need the machine to play with to find the reason.
    https://www.manualslib.com/manual/759762...
    I would send it back and claim on the warranty.
    BUNN-O-MATIC COMMERCIAL PRODUCT WARRANTY
    Bunn-O-Matic Corp. ("BUNN") warrants equipment manufactured by it as follows:1) Airpots, thermal carafes, decanters, GPR servers, iced tea/coffee dispensers, MCR/MCP/MCA single cup brewers, ther-mal servers and ThermoFresh® servers (mechanical and digital) 1 year parts and 1 year labor.
2answers
Bunn my cafe mcu red light flashing. Water does not heat. Water will run out if brew button pushed, but of course it is cold
I have the identical problem, and I noticed it this morning after there were 2 very brief (seconds) power outages the previous night. Reading around the internet I read that the fuses inside the unit are the likely culprit, and need to be replaced. You can buy fuses made by others, for this unit. But not from Bunn. And there are video instructions around that show how to do it. The fuses are crimped on, not soldered. Mind you, I haven't tried to do this, yet, but that's what I read. Good luck!
Bunn coffee pot leaking bottom
The leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
It's planned obsolescence. Bunn won't sell you a new seal. So you have to improvise. But it's simple enough to do.
Remove the top cover and the plastic water reservoir right below it. Don't tamper with the little valve that opens when you close the lid.
Look for the seal. It could be stuck to the bottom of the reservoir, or sitting loosely on top of the metal tank. Make sure to preserve its top-to-bottom orientation (don't put it back in upside down).
Apply a narrow bead of clear silicone into the grooved side of the seal. Press the seal gently onto the reservoir, then apply a thin layer to the smooth side.
Re-install the reservoir and reassemble the unit.
WHY HAS MY CAFE STOPPED WORKING? IT DOESNT DRIP COFFEE INTO CUP.
Sounds like your machine is congested. Consider cleaning out the nozzle or the filter.
How to remove the top water resivour from a nhbx bunn coffee maker
lift filler led and remove 2screws on top of reservoir
Then remove 4 screws that hold the reservoir on an you should be able to lift it off
How to fix a leak on a bunn NHBX coffee maker
Bunn nhbx leaks water
Jun 30, 2014 • Bunn NHBX
Need to open water reservoir on a bunn
Cannot remove the tank lid on bunn vps
Top Bunn Coffee Makers & Espresso Machines Experts
Marvin
Marvin
Steve
john h
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
