Re: Why is my MTX audio tna251 amp flashing red lights...
From what I can recall that is usually due to ground, a short if you will.Check your hot cable from under the hood to inside cabin the wire might of got a cut some where rubbing against sheet metal of car creating your short.
The light flashing usually means there is a short somewhere. Check your wires to make sure there are no slices and are touching. Also check to make sure you have your remote wire hooked up.
hi, your amp seems to be getting power but the cables might be wrong so it's not getting enough power. the light on the amp should be green if everything is going well.
are you sure the cables are suitable for your amp?
