My LG tv is approximately 2 years old. When I turn it on, the screen changes from black to dark blue. I have audio but no picture. I don't see any changes when I try to change input. The model number is 75UK6190PUB
Do you have a multimeter and able to pull the back off and get some voltage readings?
Testimonial: "Yes, I can do that!"
Oops, I responded in the wrong spot. Yes, I can get some voltages...
Ok good, go to the power board look for connector 201 and make sure you have 13.2 volts on pin 5, this voltage is critical on this model TV, it needs to be + or - .1 volts, also set the meter on AC and make sure you have under .2 volts ripple. If this voltage is ok and I think it will be but I'm not one to overlook anything let the set run for about 5 mins and see if the IC on the tcon board is getting warm, not hot but warm to the touch
Having the same exact issue with the exact same model. Replaced the tcon board, and that did nothing. Checked the voltage on pin 5 at connector 201, and not getting anything close to 13.2 volts. Time to replace the power supply board?
