It won't turn on. After setting od program door lock symbol starts to blink, turns off and thats it. No error, door is locked but no washing... What is wrong here?
Your are right, there is burned R263 resistor on the Board. Any idea how to find out impedance of it?Your are right, there is burned R263 resistor on the Board. Any idea how to find out impedance of it?
You can't post conmments that contain an email address.
While a program or the 'Delay Start' is
operating, the appliance door is locked and
the display shows the indicator 'key symbol '.
First set the machine to PAUSE by pressing
the "Start/Pause" touchpad. Wait until the
door lock indicator 'the key symbol ' goes off, then the
door can be opened.
If the door lock indicator 'the key symbol ' does not
disappear, this means that the machine is
already heating and the water level is above
the bottom edge of the door or the drum is
turning. In this case the door CAN NOT be
opened.
If you can not open the door but
you need to open it you have to
switch the machine off by turn the
program selector knob to the
position " 0 " to deactivate the
appliance. After about 5 minutes the
door can be opened. CAUTION !
Pay attention to the water level and water temperature.
sounds like overload protection is disabling the machine. it could be caused by a lot of reasons, the only advice I have is to check for a jammed drum, empty machine and see if drum turns freely. best luck to you.
You mean it won't turn as in it is stuck? Or is it that the motor won't come on to turn it? Check door switch. Does dryer have power to it at all? Please rate my answer so I get points for it.
