Ovens Logo
Question about Stoves Ovens
Hello, I need a replacement door hinge for my Stoves Q 720 EM DO but I can't find one online. Model number is 059850504. When I search espares etc it is bringing up a metal bar, but mine are plastic
Posted by Vicki Meneaud on
Chris
  • 26 Answers
Stoves-spares.co.uk seems to have plastic part(s)
Occasionally parts become obsolete or redesigned for cost reasons.
Metal hinge assembly from website BuySpares.com Please check the diagram & parts list if available because on certain models the original door & hinges are obsolete and you will need to order a new door as well as these are the new type hinges
You may be able to just replace the springs, unless your hinges themselves are damaged.
Posted on Aug 17, 2021
Testimonial: "Perfect - thankyou so much! I see exactly the part I need on the Stoves spares link - I searched there the other day and it just didn't turn up!!"
2answers
What replacement parts should I order to keep my Kenmore oven door from just dropping down when it is opened?
If the hinge is not broken "Check the Springs".
They sometimes come off at one end or can be broken.
There are 2 one on each hinge. They are strong so be VERY careful.
As I remember they have a color code according to how strong that are according to the weight of the oven door.
The surest way is to get the MODEL NUMBER from the tag on your oven. The parts store will be able to look up the proper replacement.
I may be able to tell you more with a model number for Identification, the oven is likely a Whirlpool Product made for Kenmore. Let me know if you are in New York City area.
Hope this helps.
Replace oven door seal
It will not be the door seal at fault. More likely is that the hinges are worn out or strained.
http://www.espares.co.uk/search/ma856pt1598/cookers-and-hobs/hinges/bosch
Try here.
Pete
The bottom oven door does not completely shutThere is a gap from which heat escapes.The door shuts but then drops open a very little way when pressure is relinquished
When the door is open, you will see some small cross head screws near where the hinges go into the door. These should be tight. If they are, then it could be the hinge failing. Try espares for a new set of hinges, but be warned you will have to take the entire oven out of its housing and both side panels off to get the the hinges.
1helpful
I have a Stoves 720 ef cooker model no 059040415. The main oven door hinges need replacing but I can not find a replacement set for this model anywhere. Can anyone help? ...
Try espares. If the part is not listed, there is a contact on the website to obtain a quote for a part. Of course once you have the part number you can try elsewhere.
The hinge on the main oven door of my heritage 900ef needs replacing. Where can i buy one from please
Well, you can try STOVES and see what they will charge, and/or try espares. Once you have the part number, google that to see if anyone else can supply.
You may want to think about replacing both hinges and the springs at the same time, to ensure the door works/closes properly. Also, check the rubber seal round the door, then tend to become brittle when at the end of their service life, so it may pay to include that with the order as well.
BROKEN GLASS ON OUTSIDE OVEN DOOR STOVES S5 600MF
You can normally replace the outer door glass independently of any other parts.
Try-----www.espares.co.uk
Plz rate my solution.
Thanks.
Open Questions:
0answers
Faulty obsolete (20yr old) oven thermostat with separate fan/light switch. Can't find a 'universal' replacement. If I fit a standard 2 tab thermostat, the fan and light will switch with the element Stoves oven DF550 SI with a 46thc502/G5 thermostat which controls well (if 40C higher relative to the oven thermometer). However after an overnight cool down the oven element switches on when the mains is turned back on, even though the oven control is off. I just twiddle the oven thermostat control slightly and all is well. I can't find a 250C, 1m phile, 24mmx6mm spindle thermostat with a separate connection tab for the internal recirculating fan and oven light anywhere. Otherwise the single oven cooker works and looks like new (nearly). I was wondering whether I have to piggy back a switch on the back of a standard 2 tab thermostat (or vica versa) or attach a separate switch to the oven. Can't believe I'm the only one with this problem. I'm guessing some fragile electrical contact occurs in the thermostat on cooldown to turn on the element and its in-series lamp, and this contact easily breaks by slightly turning the thermostat. ps there is no timer and I do have the circuit diagram. I found a working solution to this problem: When turning off the oven, I don't take it to the end stop. I turn it passed the click when the element and indicator turn off, then further till the ligth and fan turn off and just a fraction further but not to the end stop. Now the oven element doesnt turn on each time I turn the mains on for some other reason ( eg grill or igniters). I guess there is something wrong inside the thermostat, but this work arround seems OK if not ideal. I've marked a new stop position around the oven dial to remind me. This was easier than making a physical stop for the oven dial.
Top Stoves Ovens Experts
Marvin
Marvin
Narseman
Are you a Stoves Oven Expert? Answer questions, earn points and help others
