I have a Toshiba 40ft1u tv that needs a main board 461C2P51L12' 431C2P51L12' STF32T' VTV-L32606
I cant find one anywhere on the internet. I would appreciate any tips on repairing the board or another one. Tv won't power up and the power supply is good
An expert that got 20 achievements.
An expert that got 10 achievements.
An expert that got 5 achievements.
Toshiba Master
Re:
Here is a board, it's from Canada but with shipping is not to bad priced at $60. I know nothing about the seller so it's possible you could get a defective board. I assume your missing the ps_on signal from the main and that's why the set won't turn on
Testimonial: "I appreciate your help very much and your right, I'm getting no feedback voltage from the main board. The model number of the board I need doesn't match the model number from the board the link sent me to."
Thanks for the info but the board that the link took me to has a different model number than the one I need. Do you know if this board will replace the one I need?Thanks for the info but the board that the link took me to has a different model number than the one I need. Do you know if this board will replace the one I need?
According to cross reference information on shopjimmy.com the board should work in your set, it's hard to know exactly what board crosses to what TV a lot of times and it's also common for the same model to use various boardsAccording to cross reference information on shopjimmy.com the board should work in your set, it's hard to know exactly what board crosses to what TV a lot of times and it's also common for the same model to use various boards
If it is a model 32C120U, there is a known manufacturers defect. This issue is cause by defective main board because the main processor is not well solder to the PCB or the e-prom memory lost the software data. Some time you can try replace the eprom memory on the main board (cost of the e-prom $15) or re-solder with a hot air gun the processor but 90% of the cases you have to change the main board, the cost is around $30 you can find it in www.myshoptvs.com these guy are super. To replace the main board is easy and takes not more than 25 minutes.
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Can't determine the condition of the power supply board, by just examining the fuse; you know. Contact any service technician.
Check whether same things happen on headphone. Some components are getting excess voltage and heating up. Better to refer it to a qualified service technician.
Power supply, or a failed circuit board causing the power supply to go in to protect, or be damaged. You will need the service manuals, test setups, spare boards and parts to try, and especially the training.
I would consider calling the service rep for your set to get an estimate. If not, get an estimate for a new set.
