Question about Rotel Audio Players & Recorders
Rotel RSX-1065 - Can someone support me with the Firmware?
Can someone support me with the Firmware Update or the latest Firmware or a link for the Download for the Rotel RSX-1065?
Posted by Ekrem Yurdakul on
  • Anonymous Aug 11, 2021
    we are not ROTEL, and we sell no ROTEL RSX-1065 A/V Receivers here ever
    no do we sell or give away software or firmware
    I ask you now, why not ask them for support as only THEY SUPPORT THEIR product.
    also know for a fact ,most A/V Receivers had no upgrade for firmware.
    here they are, first google hit (WOW)
    https://rotel.com/product/rsx-1065
    GO THERE CLICK CONTACT AND ASK THEM,
    signed Captain Obvious.
    and is off topic as it is NOT A COMPUTER
    post here. not computer repair help. off topic.
    https://www.fixya.com/troubleshoot/rotel...
    OP if it is not broke , don't fix it, ever hear of that?
    if you brick it , do not blame me, !
Larry
  • Rotel Master
  • 4,817 Answers
Go to the Rotel website
Posted on Aug 15, 2021
Ngoro
    Top Expert:
  • 3,513 Answers
I have an old surround sound reciver ROTEL RSX-1067 Mabee 20-30-40 years old : one day it just shuts down, just like that.
Several possibilities come to mind. First shorted connections to speaker wires. Faults in the power supply. Sometimes if the unit has not been working for a while the large capacitors in the power supply can dry up.
An overload on a power transistors.
2answers
Hooking up amp to power my 2 front speakers on a Rotel 1057
Look in the manual
http://www.manualsdir.com/manuals/198428/rotel-rsx-1057.html
Rotel rsx 1065 switches on. every single thing is lit up in the display panel on receiver. But unable to select anything and of course no sound. what could be wrong?
Probably the EEPROM, the heart and brain of the appliance.
I had the same issue with my AIWA, could not figure out the cause, took it in, tech told me EEPROM is blown.
Not economical to repair.
Why my URC SL-9000 can not control ROTEL RSX-1056 AV Reveiver
Do an auto search method to search for codes. If the remote control have set-up code to your device, you will win. If not, buy an other remote control, which have set-up code/s to your device brand.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Where can we buy the remote of RSX 1067 7IN1
I do not know anything about your brand or market, but I have had good success with replacement remotes at http://www.replacementremotes.com/
They have a very wide selection of mostly refurbished remotes.
Originally supplied with RSX 1058 is this:
http://www.replacementremotes.com/ROTEL/Buy-RR-1061-RR1061-Audio-Remote-Control.html
Hello I have a rotel RSX 1056 witch I used once six years ago for two months . I lhavent used it since then , and now I decided to hook it back up and I have no audio . It turns on but when I set a radio...
If you stored it in an area with high moisture content it is probably corroded at most of the contact switches. Capacitors also hate moisture, especially paper capacitors! The tuner is also probably oxidized inside. Now is the time to be brave and pull it apart, but first PULL OUT THE PLUG from the wall. Have at it with electric parts cleaner spray and clean, dry compressed air. If you believe that just because you stored it in your house, there was no moisture, think again! Radios like cars do not do well in storage unless you take precautions to protect them!
4helpful
Cyclone media player firmware problem
Sumvision Cyclone Latest Firmware Update
Latest release of firmware to fix customer who may be experiencing "menu" problems or large HDD problems:
Please download the .zip file from the link below:
http://www.digitalpromo.co.uk/images/cyclone%20upgrade.zip
Then follow these easy installation instructions:
Info: Hard drive must be either new or contain very little data for this update to work.
1.) Extract the file
2.) Put it in the root of the HDD
Note: Dont change the file name, dont put it in a folder
3 .) Power the device on, go to the "setup" section, and click the upgrade firmware
Regards
2answers
My Rotel RSX-972 surround sound receiver has no power, the repair centre cannot isolate the problem and they do not have a service manual to guide them,a service manual would be handy??
Unless yuo can find a Rotel authorized service center, you are not likely to find any service information. These units should not be difficult to repair. Their designs are pretty much standard with a few twists. Any shop that handles audio repair should be able to resolve this. If not, please post your location and I'll try to locate a shop for you.
Also, are there any indications that the unit is trying to work at all or is it completely dead?
Thanks,
Dan
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Larry
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
