Question about Kenmore Dishwashers
Kenmore Quietguard 587.15232900A Dishwasher does not start
This dishwasher recently did not finish a wash cycle. After cleaning out the drain and filter, it will not start. The lights come on but nothing else happens. Is there a reset code for this model? Any other suggestions?
Posted by Maggie Brickson on
ADMIN Canada
    Top Expert:
  • Kenmore Master
  • 41,747 Answers
That sounds like you have a leak and the flood sensor has been activated. Look in the underneath of the machine for a pan. Do you see water in it?
Posted on Aug 08, 2021
  • 3 more comments
  • Maggie Brickson
    Maggie Brickson Aug 08, 2021
    I removed the front panel at the bottom of the machine and there is no evidence of a leak. No water, no drips, and no sign of prior water leakage on the floor. I do not see a pan.
  • ADMIN Canada
    ADMIN Canada Aug 08, 2021
    They usually have a metal or a plastic leak pan, but yours doesn't.. Here are all the parts.
    https://www.searspartsdirect.com/model/5...
    Sounds like you need a service call, but first, try disconnecting the power for an hour. That is normally the closest you get to a reset.
  • Maggie Brickson
    Thanks, I'll give that a try.
  • Maggie Brickson
    Maggie Brickson Aug 09, 2021
    Dishwasher is currently running a cycle. Thanks!!
  • ADMIN Canada
    ADMIN Canada Aug 09, 2021
    Perfect, thanks for the feedback :>)
Kenmore Quietguard 2 dishwasher not filling.
There is a solenoid that keeps the water in the washer. It is either faulty or there is something preventing it from closing completely. If there is no power applied to the washer, does it then hold water?
Why does my Kenmore QuietGuard Dishwasher Whistle?
Is it during the wash cycle? That is air getting past the drain flapper. If you install a trap in the drain line it should go away.
eric
1helpful
Water standing in bottom of dishwasher,after wash cycle is finished? This is a Kenmore model 665.1565591
My problem too recently.
I blew compressed air back through the drain line and let it bubble up in the standing water in the dishwasher. Then I put it through another cycle and everything was fine. Something must have gotten clogged and the air blew it out.
Dishwasher Clean light blinks constantly.
Try turning off the power to the dishwasher at the circuit breaker box. leave the power off for 5 10 mins and then turn breaker back on and try to restart dishwasher. This may reset the board and it may work
3helpful
5answers
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Hi Claire,
Are you using rinse aid?
that may help with the film.you may also have stuff down in the trap causing the water to drain slow.
Kenmore dishwasher not draining when finished full cleaning cycle
sounds like a cycle timer problem. Look for a loose wire on the cycle timer. If yours is a digital timer, it is a board issue. Sorry.
Kenmore Dishwasher Problems
Just for the degergent item.....The Sears repairman told me to not use the gel type detergent but only use cascade complete and to use very little of it..
Dishwashers Logo
Top Kenmore Dishwashers Experts
Paul Carew
Vernon Taylor
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
