Question about Epson Perfection V500 Flatbed Scanner
Epson v500 Photo scanner was working but now gives a red light and whirring noise when opening the app installed on Mac - gives warning "cannot properly connect with scanner".
Posted by Jeffery Hogg on
  • Larry Ng
    Larry Ng Aug 08, 2021
    the scanner is old for year 2001. XP and VISTA was last MS OS it supported ,when new.
    2009 made.
    https://files.support.epson.com/pdf/prv5...
    why not reload the scanner software.
    and last the new software from the maker i s here.
    https://epson.com/Support/Scanners/Perfe...
    always tell OS first. or answer are harder. mAC 11.x is last one.
  • Larry Ng
    page 206 read
    first is power, the scanner needs good power,
    the Epson power pack is 24vdc , 1.3amps
    there are 2 packs one for 120vac and one for 240AC is yours wrong? for your countries power
    or did you plug in the wrong power pack, ? oops. that can wreck a scanner if you did.
    try all USB ports on the unstated PC, and or , or on another PC.
    red LED see pg 205
    next time tell what PC you have maker and model and OS
    nobody can guess PC's ever, (as the book told you both ends must work right)
Epson Perfection V500 Photo scanner cover will not close
Check to see if the cover open switch is stuck or the is anything blocking the closing motion, rectify.
Epson v500 scanner says "No scanner selected" message with Mac Desk OS X
Have you installed any Printer software for this epson v500 OfficeJet 8500 Printer or just connected it for the first time
Epson v500 flashing green light
I have the exact same problem, sometimes it works and it starts warming up, but most of the time it just shows a green light and no response.
4helpful
I'm trying to install my new Epson Perfection V500 Photo Scanner. I followed the instructions. The software installed . When I turned on the switch a loud grinding noise occurred and t I get an...
Its the lock mechanism under the lid , lift the top to the scan bed and look at the lower right hand side of the inside of the lid there is a grey swithch , move it to unlock! Voila , fixed.
4helpful
2answers
WANT TO DOWNLOAD A USER MANUAL FOR THE EPSON V500 SCANNER
Epson Perfection V500 installed. My computer recognizes it and diagnostic note says all okay. B ut when I turn on the power of the scanner, the grren light comes on in the front for about 15-20 seconds and then the scanner makes a loud grating noise and the green light turns orange and keeps flashing. No scan is attempted. TGhe noise sounds like something that should be moving can get started -- but nothing moves when you look at it. Should I take it back where I bought it?
17helpful
3answers
Epson Perfection V500 photo scanner, carriage unit unable to move
I have had the sam problem on 2 of the same scanners. Open the scanner cover and slide the transparency unit transportation lock to the unlocked position. Then close the scanner cover.Power it on and there you go.Somehow this little switch can get moved and there is the grinding noise and not working.
2answers
By using the epson v500 photo I get the following massage: "Please remove the document mat and/or close the document cover" Off course I remove the mat and de document cover is close. I send the scanner to...
Possible driver issue. You have to reload the twain driver.
To uninstall the twain driver, please follow the ff instructions:
- Trash epson scan and epson scanner monitor from the harddrive
- Go to the library, then application support. Trash epson scanner module.
- Go to the library again, then image capture. Trash twain data sources.
- Go to the hd. Click on users. Click on the name of your computer. Click on library, then preferences, then epson. Trash epson scan.
Empty the trash and restart your mac.
When your mac is fully back on. Go to http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=88368&prodoid=63070478&BV_UseBVCookie=yes&infoType=Downloads&platform=Macintosh&x=23&y=13 and you are now ready to install the Scanner Driver and EPSON Scan Utility v3.27.
1helpful
Epson Perfection V500 Flatbed Scanner Logo
Top Epson Office Equipment & Supplies Experts
Ekse
Randy Prevost
Randy Prevost
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
