Question about Hisense Televison & Video
Hisense 50K360G menu keeps popping up on screen and drastically the volume turns up
As we watch the tv the menu out of nowhere started popping up on the screen and at times the volume shoots straight to 100 automatic.
Larry
  • Hisense Master
  • 3,170 Answers
This is a common issue on Hisense sets, your control pad on the TV is bad, you can unhook it and just use the remote if you would like or a new one is only a few bucks on ebay
Posted on Aug 06, 2021
Abdul Rasheed
    Master:
  • 551 Answers
Try removing the battery in the remote. If it stops happening, you need to buy a new remote. If it not, the control electronics is messing up.
Posted on Aug 05, 2021
My hisense tv keeps popping up the menu constantly
Probably a stuck button, either the menu button on the set itself is stuck or a menu button on a remote is active. Press the menu button on the set itself and see if that "un-sticks" the button, if it was indeed stuck. If the menu keeps popping up, take the remotes from the room and go back in without the remotes and see if the menu is popping up. Try the menu button again on the TV itself to see if that changes things. If the problem was a remote, perhaps it was laying wrong and depressing a button. Or, a button on it may have indeed been stuck. Bring the remotes back in and see if the menu starts popping up.
Hisense ledn40d36p wont turn on
Try turning the main power switch on the back of the TV off. Then hold the menu button and push that switch back on while still holding the menu button. Keep holding the menu button until the setup menu pops up.
http://furnace-repair-edmonton.ca/furnace-repair-installation-and-check-up
My hisense tv menu keeps popping up and sound going up and down and select source keeps popping up to
Hisense support is very good but this issue may be a firmware issue. They can send You an update for the firmware but I have not had any luck using them.
2answers
On my Hisense 50K23DG LED TV, I have sound but no picture.
LCD & LED TV Repair - No Image & Blank Black ... - YouTube
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on the Screen CLICK HERE to BUY ... I have an LG ...
Hisense 50K360G has audio no video will not turn on logo ...
? 1:48
https://www.youtube.com/watch?v=xI3MpZukKm0
Nov 20, 2013 - Uploaded by After Hours Tv & Pc repair
Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http://bit.ly/ShopJimmy6 Want to ...
All comments on LCD & LED TV Repair - No Image & Blank ...
https://www.youtube.com/all_comments?v=xUzCLgoSPGM
I have sound and picture but no backlight. .... how do you replace the back lighting on a led lg tv? ... I have a 42 inch LED LCD combo DVD TV made by RCA.
My LED TV has sound, but no picture. - Tom's Guide
www.tomsguide.com/answers/id-2771720/led-sound-picture.html
Dec 28, 2015 - Hi, I have an RCA 32" LED 1080p TV that is less than 2 years old, and it has already lost the video. I can hear sound, and I can see lights in the ...
53 HISENSE complaints and reviews @ Pixxed Consumer
hisense.pissedconsumer.com/
My screen indicates hdmi 720p on the top right corner then the video menu pops up. it goes back and forth making watching tv unbarable. also the volume flashes when it is pressed i have a Hesense 32 inch...
The HDMI 720p pop up,because on the tv Menu setup OPTION,U pick YES on the tv Program Title Display option,pick NO should stop the pop up HDMI 720p indicator.The volume bar indicator pop up when it press the button to turn volume up or down it is mornal functions of the tv.
1helpful
2answers
Hisense flat screen has locked
Try turning the main power switch on the back of the tv off.
Next, be sure your input is set correctly(air or cable).
Next, do an auto channel search.
That did it for me. After I shut it off I had to do it one more time but it did the job. A friend of mine gave me the tv for free because nobody he new could figure it out. I took it home, got lucky, and figured it out in about ten minutes.
jb
Televison & Video Logo
Top Hisense Televison & Video Experts
Jean Sintulaire
Ekse
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
