Question about Car Audio & Video
SL. Radio turns on, but why is there no sound?
Posted by Daniel Garcia on
Larry
  • 3,158 Answers
Bad audio out ic
Posted on Aug 10, 2021
Tom Chichester
    Top Expert:
  • Car Audio & ... Master
  • 62,168 Answers
The Murano may have a separate amplifier that has a separate fuse.
Posted on Aug 05, 2021
My 2001 Saturn SL is making a buzz noise under the dash, but stops when i use my blinker or hazards, why?
Noises have to be heard to diagnose, so please have an expert look into this with ears on.
Radio/Nav is malfunctioning; unresponsive, shuts down/reboots, slow to react to inputs
The only thing that you can do is remove the unit and send it out to a factory approved repair shop, that is it no other choices.
2answers
Saturn sl1 won't turn over when dome light and radio won't work
sounds like the rke module (Remote Keyless Entry) module losing power, I hope that helps you out
Keenwood radio turns off at a certain valume in my Nissan 2007 what can it be?
sounds like its a power supply problem ,not enough power for your deck, if you can connect to a better power supply
My 97 Saturn SL! has a new starter, altinator and battery. When you turn the key to start it, there is nothing including any kind of sound or noise. The radio, lights, and blowe come on telling me it is...
IF STARTER FUSE AND RELAY OKAY.REPLACE THE NEGATIVE BATTERY CABLE COULD HAVE BAD GROUND AT CABLE.IF CABLE GOOD. I AM LOOKING AT FAULTY IGNITION SWITCH OR FAULTY TRANSMISSION SAFETY NEUTRAL SWITCH.
1helpful
MY SATURN 2002 SL1 WILL NOT START. MY BATTERY IS FINE BECAUSE ALL LIGHTS AND RADIO WORKS BUT WHEN I TRY TO START IT, IT MAKES A CLICKING SOUND.
A quick check, is turn your headlights on, try to start, if lights dim almost to off, bad battery, if they don't dim, it's a bad starter assembly.
1helpful
2answers
My 91 Cutlass Supreme SL car radio isn't working?
Hello! Have you recently disconnected the battery? If so the radio is locked. If you do not have the unlocking code, take the vehicle to an authorized Oldsmobile dealer, give them the VIN# plus proof of ownership and they will give you the code...
Guru......saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
1helpful
Radio stuck on loc
power radio on then hold 2 and 3
Technics SL-HD350 Cd Player - Sound problems
This maybe due to overheating of some Sort.
Try taking it out of where it is where theres a good flow of air.
Then try running a cd.
Try Putting in a Cleaning cd, this maybe a fault with the laser.
Regards
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
 Francisco Mauricio...
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
