Question about Seiki Televison & Video
My seiki sc3200H tv wont turn on it shows a red power light but it does flash when try to turn on with remote and wont turn on with main power button
Posted by Brenda Shine on
Larry
  • Seiki Master
  • 3,157 Answers
Your LED backlight lamps are bad.
Posted on Aug 04, 2021
    Top Expert:
  • Seiki Master
  • 76,758 Answers
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
https://homenol.blogspot.com/
https://elektrotricks.blogspot.com/
Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Search the sites by type in the brand name of your set, in its search box at the right column. View it on a desktop or in web View by mobile. Mobile view has no search box.
I have a new Seiki 32 inch tv. Xfinity XR11 remote will turn off the tv but will not turn it on. Also, when you hit the mute button on the Xfinity remote it displays the input choices on the tv?
  1. Turn on your TV.
  2. Press TV on your remote. ...
  3. Enter 9-9-1 and the TV button will flash twice.
  4. Press 1 and the TV button will flash twice.
  5. Press the Power button, then press CH+ multiple times until the TV turns offs.
  6. Once the TV turns off, press Setup to lock in the code.
Hi everyone... Having a dilemma with my seiki TV which it shut off and the power light is flashing on and off in red. Has anyone else had this problem with this brand and if yes what was the solution to...
I never use such of TV but what I no your TV can be in stby mode plizbtry to use stby button on your handset remote controller, if you have no remote try to use buttons on your TV panal press v+ or v- buttons or try other buttons it can switch from stby .thanks
1helpful
Hi im trying to set up seiki tv, when turned on at the mains the blue indicater light comes on, it starts to flash blue and pink goes off then comes on again. The screen says the SEIKI logo.
Something the weight of the TV flexes the buttons on the edge pushing on power button in this case ,. Causing unit to turn and off before it comes on all the way .
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
https://www.youtube.com/watch?v=iHBIiRxhe0w
Sep 26, 2014 - Uploaded by ShopJimmy.com
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. ...tv to come on bcause the power button keep blinking my tv will not come on.
2helpful
My seiki tv shut off while i was watching it and it wont turn back on.... the red standby light and front panel lights work so the tv is getting power however it will not turn on with the remote or the...
Someone is going to have to open it and examine the power supply board in the set first for signs of damage or puffed up caps and then check for various voltages, This set is likely to be a problem for parts as all brands can be as they only sell circuit boards, the question becomes which board is bad?
6helpful
2answers
TV won't turn on, red flashing light
Hold The Off Button for 20 sec should make clicking noise switch off at power and on again should be working
79helpful
3answers
Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Televison & Video Logo
Top Seiki Televison & Video Experts
ADMIN Canada
ADMIN Canada
MrFixitSTTL
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
