My portable victrola record player isn't working i've already bought a new power cord and have tried using multiple outlets around my house and it just doesnt power on help please!!! : /
Larry
  • Televison & ... Master
  • 3,157 Answers
It may have power supply issues, if you have a multimeter pull it apart if you feel ok doing that and test the various components in the power supply section
Posted on Aug 04, 2021
I have a VSC 550BT. The tone arm slides across the record. Is there a weight/ counterweight that can be adjusted? Where and how?
I have not had a record player for 20 years. When I had one and I put the arm on the record and it slid across the record to the middle of the record the problem was it needed a new needle. It is the pointed part which contacts the record.
I found this manual info below hope it will help
Victrola VSC-550BT Operating Manual
https://www.manualslib.com/manual/1341772/Victrola-Vsc-550bt.html#manual
Victrola VSC-550BT Operating Manual: Troubleshooting Guide
https://www.manualslib.com/manual/1341772/Victrola-Vsc-550bt.html?page=15
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
I've just bought a new remote control as the original isn't working. Is there a set up routine that one has to follow?
If you bought exactly the same remote, then it should work without doing anything (just make sure it has batteries) if you bought a Universal Remote, you should input the codes for Panasonic first.
1helpful
I have a GE D52GW12 rear projection tv. It seems to just loose power and turn off at random times. I already tried different outlets to get it working again.I can get it back working if I wiggle the power...
The tv a/c power cord have internal damages short on the head of the a/c plug itself.This work job is pretty simple if u can do a basic soldering jobs and have tools like a soldering iron and a roll of solders.Look around in ur house for a table portable lamp u don't used anymore unsolders and take that portable lamp a/c power cord.It have very simular design and make of a power a/c cord.Take the tv aparts simplely just unsolder the old tv power a/c cord and replace it with a portable table lamp a/c power cord.Those stars srews on the tv are called Allan wrench screws,must a have a set of Allan wrench screws drivers to use take out this screws out of the tv.Some ealier DLP tvs set made by GE are using these Allan wrench screws,tries to make it much more difficult to take the tv aparts as GE they're trying not to allow tvs owner to take the tv aparts.Or have any friend to help u can do it,have a soldering iron,a rolls of solders,have basic soldering skills.A Allen wrench screws drivers set u can buy it anywhere in a hardware store.
Power cord jack not connecting, cannot recharge battery or power dvd player. power cord itself works well on other toys.
I have an SV2000,DVD / VCR I bought Sony Dvd`s to record from Tv to DVD and when I press record this comes up.E 4 54040990.I have tried cleaning,that does not work.I have had this DVD/ VCR about 3 2 to 3 yrs.Why won`t it record. I am so weary with it,
2answers
Useing in the car
It doesn't have a car adapter but you can purchase power inverter for the car so that you can hookup any electronics just like at your home. The power inverter converts your car power into multiple outlets.
Fuse Keeps Blowing In Car Plug
try using a 3a or high fuse
You can buy a new car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand DUAL 7" dvd player
Televison & Video Logo
Top Televison & Video Experts
Ekse
