Porter Cable 18 - Gauge Brad Nailer and Compressor Combo Kit Logo
Question about Porter Cable 18 - Gauge Brad Nailer and Compressor Combo Kit
Leaking sound coming from top
My Porter Cable 150 PSI air compressor is making a "hissing" noise. It had a problem of not starting but that has been cleared. If I fill the tank with any amount of air and turn the compressor off, it makes this hissing noise until all the air is out of the tank. I noticed a small pin-hole in the hose that goes from the tank to the compressor (This is not where the hissing is coming from). I've tried the tapping on brass valve with no success. Aside from replacing the hose, is there anything else you think needs replacing?
Thanks,
Jason
Posted by jason_c_belb on
  • jason_c_belb Sep 20, 2009
    I don't see this non-return valve anywhere on the unit. The only connections to the tank are the check valve and the manifold assembly. I'm looking at a site that shows me all the parts to this unit http://www.ereplacementparts.com/porter-... Let me know if you have any other ideas. Thanks!
    I don't see this non-return valve. I'm not sure if this is on a different model. Mine only has the check-valve and the manifold stuff. Any other ideas?
Anonymous
    President:
  • 1,167 Answers
Hi buddy the pipe that comes from the pump to the tank connects to a non return valve (pic below) on the tank unscrew the end of this and turn the rubber around inside and try this get back to me if no difference Leaking sound coming from top - 9d71ea5.jpg
Posted on Sep 20, 2009
  • 2 more comments
  • Anonymous Sep 21, 2009
    buddy i think i can see it in the picture next to the pressure switch
    it may be behind the cover inside the cover
    hang on a mo buddy a check valve is a non return valve lol
1helpful
My porter cable C2006 air compressor airs up to 30psi then shuts off at 30psi and repeats once the psi gets low enough?
it has 2 gauges , one for tank pressure and the other is the regulator output. tank pressure is on left. The pop off is starting to release because is worn and should be replaced. if unit is only making 30 pounds on tank gauge you have other problems . If that is true personally i would replace it.
https://www.ereplacementparts.com/porter-cable-c2006-type-compressor-parts-c-129_1662_16249.html
1helpful
Porter Cable 150 psi 6 gal compressor tank builds up to 150 psi but 'regulated air' stays at zero and, of course, no air out. Thanks
The attached link provides a work around,
There are repair kits available. Dissemble and make sure that you document the assembly for reassembly. Common problem.
Hope this helps.
Fixing Porter Cable C2002 Regulator
My Porter Cable pancake air compressor is getting too hot and melting my air hose
ASSUMING THIS IS AN ELECTRIC MOTOR DRIVEN SINGLE STAGE COMPRESSOR, IF THE COMPRESSOR USES OIL IN THE CRANKCASE, THE PRESSURE SWITCH SHOULD CUT OFF AT 125 PSI AS THE ACT OF COMPRESSION HEATS THE AIR QUITE HOT. THERE IS ALWAYS SOME OIL THAT PASSED THE PISTON RINGS IN THE COMPRESSED AIR. IF THE COMPRESSED AIR GETS HOT ENOUGH, THE OIL VAPOR CAN IGNITE AND THE FLAME CAN CARRY TO THE TANK FOR AN IMPRESSIVE EXPLOSION. THIS ORDINARILY DOES NOT HAPPEN BELOW 175PSI OR MORE.
OILLESS COMPRESSORS CAN BE SET TO 150 PSI. WITH EITHER TYPE OF COMPRESSOR, THE HOSE SHOULD BE ATTACHED TO THE REGULATOR OR THE REGULATOR STACK, NEVER TO THE COMPRESSOR, AS THE COMPRESSED AIR LOSES MUCH OF ITS HEAT WHILE IN THE RECEIVER. IF THE WHOLE TANK IS GETTING HOT ENOUGH TO MELT A PROPERLY ATTACHED HOSE, YOU HAVE A DANGEROUS SITUATION, CHECK THE OPERATION OF THE PRESSURE SWITCH, UNLOADER VALVE AND RELIEF VALVE. THE RELIEF VALVE SHOULD OPEN AT NO MORE THAN 150 PSI, THE UNLOADER VALVE OPENS WHEN THE PRESSURE SWITCH SHUTS THE MOTOR OFF, AND SHOULD ONLY HISS FOR A FEW SECONDS AS IT DUMPS THE PRESSURE ONLY IN THE COMPRESSOR AND THE LINE FROM THE COMPRESSOR TO THE TANK INLET CHECK VALVE. IF THE UNLOADER VALVE HISSES MORE THAN A FEW SECONDS, THE TANK INLET CHECK VALVE IS LEAKING AND NEEDS TO BE SERVICED, CLEANED OR REPLACED. IF THERE IS CARBON BUILD UP IN THE VALVE, THERE IS EXCESS OIL PASSING THE COMPRESSOR PISTON RINGS, REPLACING THEM MIGHT FIX THAT IF THE CYLINDER OR RING LANDS ON THE PISTON ARE NOT TOO TAPERED OR WORN.
Why does the safety valve go off before the pressure switch on a porter cable 80 gal air compressor
The maximum pressure on most small compressors is 10 bar or 1000kpa which is about 145 psi in the old language most safety valves are set to 150 psi. I suggest you get some one to reduce the pressure switch setting. Running a compressor at elevated pressures does not give you any more air. A reasonable pressure for small compressors is 120 psi
A porter cable 135 psi 60 gallon upright
If the motor doesn't shut off at the desired pressure then your pressure switch is either set too high or is broken/stuck. The pressure leak at 150 psi is the safety valve doing its job opening when the pressure gets to an unsafe level in the tank.
Air has started leaking around the plus/minus knob on the front of my "Porter Cable C2002 150 Psi 6 Gal Compressor." As a result it no longer can fill up with air. What can I do to fix it. Jim
They will let air out if you have turned the valve out too far, try turning it clockwise until it stops then open it by turning the other direction two or three full turns.
Don F
It will not build pressure in the tank.
There is a pressure relief valve somewhere around the motor. Make sure it is closed. If the relief valve isnt leaking air while the compressor is running you probably have a loose hose on the line going from the compressor to the guages or the overpressure valve. Something under the motor/compressor cover.
1helpful
Porter cable stand-up air compressor starts but air won't fill up
Might be the unloader valve is stuck. if so there will be hissing noise from switch assembly and you may have to get a new one.
Top Porter Cable Air Tools & Compressors Experts
David Shaub
Jay Finke
Jay Finke
JOHN LAPIER
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
