Question about Kenmore Refrigerators
Elite 7957248. Freezer section is cold. Why not the refrigerator section?
Posted by Fiona Ireland on
Marilyn May
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 69 Answers
Try turning the dial to cooler fridge or warmer freezer. Middle setting
Posted on Aug 02, 2021
What part do I need to repair my kenmore elite refrigerator?
you call a local repair service . it probaBLY NEEDS FREON ADDED AND ONLY TECH HAVE THE TOOLS REQUIRED
Kenmore classic bottom freezer refrigeration warm but freezer is cold
I would guess you have just caused a build up of ice to block the air way, which normally takes cold air into the fridge. manually defrost (unplug and wait until the ice goes away) then restart and it should be fine
I have a kenmore elite coldspot side by side refridgerator and it is not cold enough on the fridge side. How can i fix this?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Kenmore elite fridge, french doors, bottom freezer: water does not come out cold. What should the temperature settings be at (for fridge and freezer)?
Fridge 34-38 degres
Freezer below 29
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
My kenmore elite side by side is making a buzzing
The buzzing noise is likely coming from the main power board and will need to be replaced.
2helpful
Bottom frezzer is working but fridge is not blowing cold air
Refrigerator gets cold air from freezer compartment. Either the air flow is blocked by food items or ice, or the recirculating fan is not working.
The most common failure is that the freezer coils get all iced up becuase the defroster timer, defroster thermostat, or heater has stopped working.
When it's running, you should feel cold air blowing out of the vents that are in the fridge, otherwise, the 'air tower' (air vent) is blocked with ice.
If you manually defrost the whole thing, and it runs fine for a day or so, then it's not defrosting properly. If you manually turn the defroster timer, and you don't hear the scorching/hissing/gurgling of the defroster working, then that would confirm a fault in the defroster circuits.
Based on the following thread, it's probably a bad defrost thermostat.
http://www.applianceblog.com/mainforums/sears-kenmore/13766-kenmore-elite-22-bottom-freezer-refrigerator-fridge-not-cooling.html
Only the freezer is getting cold
This would indicate that the unit is short of refrigerant.
Refrigerators Logo
Top Kenmore Refrigerators Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Paul Carew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
