Question about Electrolux Washing Machines
Front loader. Why is there water in drum?
Clothes are done perfectly. Go to do a second load the next day and there's water in the drum
Posted by Kathleen Gochenour on
Jorge Rendon
  • Electrolux Master
  • 5,541 Answers
YOU MAY HAVE A BAD WATER INLET VALVE NOT CLOSING PROPERLY?
Test the water pressure level switch a pressure activated switch that is used to determine the correct water level in the tub. This part is normally located behind the control panel and will have a hose or air dome tube that connects it to the tub. On washers that use an electronic control, this switch may be located at the sump area below the tub. As the water fills in the tub it will compress the air in the tube and push against a diaphragm inside the switch. The switch will control the water inlet valve and turn the valve off at the correct water level. If the tube has a leak, not enough pressure may be created to activate the switch and the washer may overfill. If the switch is defective it may also cause the machine to overfill. To determine if the switch is bad, you should first eliminate the air dome hose as a problem. Look for signs of cracks or worn areas on the hose. Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. If the air dome hose appears to be ok, then the water level switch may be defective.
You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube.
If the machine starts to wash. the pressure switch is more than likely good
( No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED).
# Test procedures to follow when a GE Hotpoint washer is not filling
* Disconnect the washer from the wall outlet
* Set the timer dial on regular and pull the knob to turn the timer push-pull switch on
* Set the temperature switch to the cold/cold setting
* Open the controls panel to gain access to the water mixing valve solenoids
* Touch the 2 terminals on the cold water solenoid with your volt meter test proves. Make sure that your body don't touch the washer cabinet, this eliminate the chance of getting an electrical shock.
* Have someone plug the washer cord for you while you check the voltage
* The reading should be 120 volts
* Touch the 2 terminals on the hot water solenoid with your volt meter test proves. Remember, to keep your body from touching the washer cabinet to eliminate the chance of getting an electrical shock
Have your helper plug in the washer cord again so you could check the voltage at the hot water solenoid
The reading should be 120 volts. If you get 120 volts, this tells you that the wall outlet, the timer, the water temperature switch cold and hot water settings are working ok.
If the GE Hotpoint washer is not filling, the problem should be on the water valve, the screen filters or the water supply
If one of the solenoids is bad you will need to replace the complete water mixing valve assembly YOU SHOULD ALSO GET AN OHMS READING OR SHOW CONTINUITY WHEN TESTED UNPLUGGED ON BOTH SELINOIDS HOT AND COLD
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
Front loader. Why is there water in drum? - inlet testing washerwater inlet valve-undefined-undefined-0_3.jpg
Posted on Aug 14, 2021
Electrolux gas dryer snagging clothes
Good Morning Friend,
I understand your Electrolux gas dryer, model# EIGD55HIW, is snagging and tearing your clothes. There is a possibility that the temperature is too high and you are overdrying your clothes. Make sure to dry your clothes on the correct temperatures and correct times. The other possibility is, the finish inside of your dryer has been scratched or chipped. This can cause a snagging or tearing of clothes. To prevent further scratching and chipping of the drum finish, make sure to always remove any foreign objects from pockets before laundering, as well as make sure zippers and fasteners are not hitting the inside of the drum. Hope this is helpful.
-Best Regards-
WP
1helpful
I have an IQ touch front load washer. lately I have noticed a mildew smell coming from the clothes and drum after washing. i have followed the manual and completed the refresh and comlete cleaning...
Water can remain in ANY washer after the load is done. With a top-loading washer, it's easy to leave the lid up so that the water evaporates. With a front loader such as yours, however, the open door can take space in your laundry area, so we usually close the doors. I suggest that you take a dilute solution of chlorine bleach and water and put it on a disposable cloth and wipe down the inside of your washer as well as the areas around the door itself and the part of the washer that the door closes onto. Once you've done this, leave the door open until the smell dissipates OR overnight. If you will get into the habit of leaving the door open for a couple of hours after you're done with your laundry, you will probably solve the problem.
I really hope this helps. If it does, please come back to Fixya and rate my solution.
Hi can you tell me which programme is the short wash and spin please
I think I have the same type of washing machine as you do. Wash is when all the clothes get agitated or mixed with soap and water (ever look in there when its washing? the water can get pretty gross looking!) So in my washer, the rinse cycle is when all that gross water is drained, and the washer spins while spraying clean water over the clothes to get rid of the dirty water and soap. I think mine does this 5 or 6 times in the cycle. Next is the spin cycle, which is when the washer spins REALLY fast to **** as much water out of the clothes as possible, so that the clothes aren't sopping wet when you put them in the dryer.
It sounds like your mom has a newer washing machine, probably a front load one, and they do seem to keep using clean water, instead of just agitating the clothes in dirty water.
After I take the clothes out of the washer there is no water in there but when I go back the next day to do another load there is water in the drum. What is the problem?
Sounds like the fill valve is not shutting all the way off. If you shut off the water after use and no water shows up you should replace the fill valve before you get a flood
1helpful
3answers
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
I have a new electrolux front load washer. When
Mine only smell mildewy if I leave them in more than an hour before drying. My old top load washer did the same thing. I dont wash unless I can immediately switch to the dryer.
My Electrolux washer is only 6 months old and the drum has started squeaking. What could the problem be?
NOT Solution - I just bought one last week and it squeaked for me today. Sounded like a belt. As the washer added more water to the drum to soak the clothes, the squeak went away. So not sure if belt slightly out of alignment - hence it rubs or perhaps a roller knob needs adjustment is what I am thinking.
2answers
Kenmore Front Loading Washer - Water in drum
please hold my rating till were done i need your model number to give you the proper procedure for checking your drain pump as i believe something in it is restricting your drain flow and three different companies build kenmore
3answers
Loud squeaky Noise
this is not 100% diagnosis as can't listen to noise but fault may be bearing lip seal disintegrating which is a serious fault and if im right then bearing will shortly go as well. reason it is noisy during start is that seal is dry and gets wet when full of water
Washing Machines Logo
Top Electrolux Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
