Question about Marantz Audio Players & Recorders
I have a Marantz ST100. Speakers not playing after making a loud POP sound.
I have a Marantz ST100. I havent played in in a couple of years I went to listen to it and I turned on receiver and radio was playing through speakers. I turned on CD and hit CD input button on receiver and a loud POP came through the speakers and now I have no sound. Everything is powering up but no sound from speakers at all. I wonder what happened? Thanks so much.
Posted by 5XChamps2 on
Tom Chichester
    Top Expert:
  • Marantz Master
  • 62,329 Answers
Dried out electrolytic capacitor(s) shorted
Posted on Aug 01, 2021
  • 5XChamps2
    5XChamps2 Aug 01, 2021
    Thank you so much
Just had Marantz 2235B serviced however after 2 hours of playing some vinyl, I hear fuzz and a pop in the left speaker. Now, no more sound from receiver.
Fuzz and pop sounds like bad capacitor or blown transistor.
Best to take it back to service center.
While there, throw your toys out of the cot, explaining that they did a 'b*m' job.
Marantz 1170 was playing music and started turning up volume all music shut off what's the problem
how old is that unit ?
cant find a picture of a 1170
faulty volume dials or slides
internal fuse ?
power source over heating
just how load = enough to pop the speakers
My Marantz SR6200 is not playing loud and it only plays in analog and when it does and I select tuner cd or Dvd will play, there is also a little crackling on the front right speaker. please if anyone...
Hi, maybe you have speakers misconnected or speakers wiring with short circuit (joined bare cables), please check them because if this continues for a long time, your device could get damaged.
I have a marantz st100 receiver, and everything seems to work well with one exception. There is static in one channel that comes and goes, and sometimes gets quite loud. The problem follows the channel...
It could be a burned out resistor in the main power amp. Follow the channel wires from the speaker that is playing up till you get to the power amp. Look around for anything odd. Compare it with the other channels, as they are good.
Marantz SR5500 B speaker setup problem
are all the speakers connected 1.5s
all the same watts helps
is that one with an inbuilt amp ?
what a mess or connectors at the back of one of these
Model SR5500 User Guide - Marantz
us.marantz.com/DocumentMaster/US/DFU_SR5500_Final_Eng.pdf
1helpful
There is no sound coming from the speakers on the SC-HT900 dvd home theater sound system. It used to make a loud pop sound but then would still work. Now it does not make any sounds. The dvd will play...
May be a fuse inside blown , if it makes a loud pop that can take out a fuse, If you find one blown , replace with same type and try machine .Dont replace with higher rated fuse though , if it keeps blowing. Try using headphones and if you get sound , may be speakers.
pete
1helpful
2answers
Audio glitch on Marantz SR-19
It's probably not heat due to the Marantz' large frame and heat-synchs.
This could simply be a mismatch of impedance. The amp is 120w per channel, so make sure the speakers can handle this. Check the impedance (ohms) of the speakers and the amp as well. Clipping can be caused by overpowering the speakers, which could damage the speakers in the long-run.
If this is only from 1 source- (i.e.- Blu-ray player or cable) then it could be digital clipping.. This Marantz can decode 96kHz PCM or normal Dolby Digital & DTS. If this is a Blu-ray it may be streaming 192kHz PCM... (but most likely the Marantz will not even attempt to play that audio)
I hope this helps.
Woofer popping
Sounds like a loose connection or a blown speaker. I would try just playing around with the wires to see if you can make it pop, if so, the wire you were messing with is the most likely culprit. Also, verify the sub cone has no damage or cracks. I am betting it i a bad connection or a loose wire.
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Speaker makes a popping sound when car starts
may be the antenna jack such is connected in cassete is n't good
Open Questions:
Top Marantz Audio Players & Recorders Experts
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
