LG 55 in. Replaced backlights. Why is there a black screen with one white strip (about 2-3 inches) near the left side of the screen?
Replaced backlights because the screen had a blue tint.
Posted by Brandon Musso on
Larry
  • Televison & ... Master
  • 3,206 Answers
I hate to give you bad news but your damaged the panel when you had it out and now the TV is junk, a blue screen is generally caused by a bad main or tcon board but it's to late for that if the screen is damaged
Posted on Jul 31, 2021
    Top Expert:
  • 76,763 Answers
That is not the fault with backlight. Contact any service technician. If you wish to get some details; check the sites linked here.
https://elektrotricks.blogspot.com/
https://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault . Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in Webview with mobile or by desktop. Mobile View has no search box. Screen-shots to defective LCD panels are given. You can see and compare to that to your TVs', and can make sure about the fault to an extent.
Lg 60lb6100UG - Left side of screen is dark, but the backlight LEDs are all working. What could be the issue?
If all of the back lights are light up, the problem mostly is the display panel. we have seen a few of them.
1helpful
Not Solved 9/17/18 A 9 yr old 55 LG LCD tv I need help with. Model 55LH55-UA w/ black screen exhibiting the following: -turning on tv by remote or on the side, blue ON light comes on, screen is black.
Sounds like you have LED backlights that are going bad and the strips need replacing, its not a real easy job but if you watch some youtube vids they show how to do it.
Samsung UN55HU7200FXZA. Black screen. When turn on,Verticals white & black lines, and after 2 seconds goes black (no video).
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
How do i test a backlight for a led tv
Testing TV Backlight LEDs - YouTube
? 4:44
https://www.youtube.com/watch?v=eEJoPCa7Kt0
Jan 24, 2015 - Uploaded by swappart.com
... explaining easy way to test individual LEDs on a strip from aTV backlight. ... Sharp LC-60LE820UN TV - LED Strip Testing - Long Version ...
IT02 - How to Test LED Backlight - YouTube
? 0:55
https://www.youtube.com/watch?v=YmSI2N6BGPA
May 20, 2011 - Uploaded by LCDPARTS
How to use IT02 to test Laptop screen LED backlight.
LST04-TV, How to test LED TV screen - YouTube
No video no picture, caps look okay, what could be wrong or how to tshoot to determine which PCB is bad etc
Does the screen flash on briefly then go black when first switched on? See my posts in march for my answer to this fault.I traced the same fault on my own tv down to a faulty led in the backlight strip. Also my tv did the same thing,standby light flashed twice and then went out.Hope this helps
1helpful
Strips of 2 inch wide black and white, running top to bottom
Definately a damaged screen, no way to fix it for less than the cost of a replacement screen sorry.
Televison & Video Logo
Top Televison & Video Experts
Ekse
