Televison & Video Logo
Question about Toshiba Televison & Video
My Toshiba TV VCR Combination has sound but no picture, just snowy
Posted by Cheryl Briard on
brian williams
    Genius:
  • 1,980 Answers
What color cables are you using?
Posted on Jul 29, 2021
No picture on my TV/vcr combo when playing VHS tape.
I suspect either the playback head is very dirty and needs cleaning, or it's malfunctioning and needs to be replaced.
No sound, no picture
Try with external monitor and let me know did u see ur desktop with external monitor?
OK?
My TV/VCR combo is not showing the picture of my movie in the vcr. The picture is snowy, but there is audio of the movie. Do you know what the problem is?
try changing the channel from 3 to 4 or vice versa. You will usually get sound but no picture if its on the wrong channel
3helpful
Tv has only snowy screen. Used the remote to
What to do if you have an all snowy picture (blue screen or the TV displays unusable signal-no signal or no sync)
1 – If you are using a digital cable box or satellite receiver (make sure it’s on) and be sure your TV is set for either CH3 or CH4 (which ever you usually view it on). If you usually view it through video inputs (video1 or 2 etc.) make sure the appropriate input is selected.
If you still don’t get a signal see if you get picture using the DVD or VCR (if available) if you do than plug the satellite or Dig. Box temporarily into the place of the DVD (unplug DVD) you may have to use some A/V cables (RCA yel./red/wht like the ones on the DVD) to hook to the tv from the sat./dig. box. If you get a signal then the sat./dig box is ok. If not the Sat./dig box is not sending a signal and is either defective or needs to be rebooted (unplug wait 5 min try again).
2 – If you are using standard cable or antenna (source) if possible check that the source is good by connecting to another TV. Otherwise try running the source into a VCR and then out to the TV using video inputs (RCA yel./red/wht like the ones on the DVD) and then selecting the appropriate input. Try seeing if the VCR plays using standard CH3 (or CH4)
If the VCR plays on video input but not when connected to CH3 (CH4) then the tuner of the TV may be defective – see if you can use the VCR to change channel using the VCR remote.
Be sure to vote/rate me if this helped Thanks!
We have a new vcr snowy
It seems that you need to take the new unit back for exchange, since you are using the same output for the vcr and the dvd and your dvd is giving you a good picture, the vcr is acting up and since it's new either exchange or repair will be needed.
2answers
Vcr will not record sound any more.
Try with another cable, the cable may either be loose or damaged. If that doesn't work it is a problem with the VCR itsself
2answers
Snowy screen on tv
the 3 or for setting on the vcr is on the back( a switch)
or if the cable box has a channel 3 or 4 setting on the back of the box
but otherwise the tv may need some work on the tuner or need a new tuner
Akai problem
i got akai 29" tv before 1 1/2 yrs back.3days back it was burnt with a huge sound. the set was burnt with a high smoke.since 1 wk i am waiting for your service agent.when they will come?this problem was not present in sony,LG,or other tv.akai is this much weak set.there was no lightnening only rain was present at that time.i hope you will change the set with free of cost.
K.P.Varghese,Plot.330/54,St-3E(East),Pragati Nagar,Risali,Bhilai,Durg(C>G)Pin-490006
Phone:0788 2271393,Mob:9424124176.
2helpful
2answers
Emerson ewc1302 13 in. tv/vcr combo problem
We had that same problem. Try a VHS head cleaner. Worked for us.
Tv won't tern on
dont know how to tern on a tv, I do know how to TURN on a TV though...
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
